36 ft trifly cradle
rooferdave
36 ft trifly cradle
Post by rooferdave »
anyone have drawings for one of these? I have a similar boat in my club but it is sooo buried with all the other cradles I will need towmotor to dig it out, any help wood be appreciated.
Dave
ready123
Post by ready123 »
why build a cradle... why not block the keel and use stands to prevent tipping like this?
http://www.yachtworld.com/core/listing/ ... e=Photo+38
rooferdave
1 or two reasons...rules of the club I am in require that you have a cradle for your boat, also as the property we are on is in constant motion, if not on a cradle, the land can shift and boats have fallen off stands in the past
If those are the rules then you're stuck. But if it's because the ground moves off season, it's a poor reason for forcing members to use cradles. When done properly and maintained off season, shifting grounds or high winds shouldn't make a difference. Is the place shut down completely in the winter with no staff around?
ready123
Post by ready123 »
rooferdave wrote:1 or two reasons...rules of the club I am in require that you have a cradle for your boat, also as the property we are on is in constant motion, if not on a cradle, the land can shift and boats have fallen off stands in the past
That sounds like the cradle will need to be quite substantial then to absorb shifting ground better than correctly placed stands.
In my view adjustable stands placed around the edges of a boat for support, not weight bearing are likely to be more adjustable for ground shifts than a cradle.
But rules are rules.... can you not just measure your hull and design one? My guess is the cradle would have side ribs that align with the sling points on your hull and the main support is on the keel.
13footbeam
Post by 13footbeam »
You can easily, well with effort make a heavy duty cradle that will support your keel with adjustable stands built in to keep your boat upright. About 10 years or so ago I was one of the proud owners of the Indian River Marina in Michigan and we pretty much built and rented to our customers this very type of cradle. They were pretty cool, could be used for many boat hull designes.
Pat
Love my Trojan Boat
Current Fleet:
77 36' Trojan Tri-Fly
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
80 9' Achillies dinghy (sold)
80 26' Pearson (sold)
77 13' Pintail
01 4 person paddle boat
96 Hand Made Wooden dinghy
rooferdave
during haulout approx 200 boats are hauled out in one day with 2 640 tonne cranes, there is 1 expierienced swamper and a bunch of designated haulout crew from the club. They do not have the skills to set up stands and so must have premade cradles to drop the boats on.
ready... in reply to your question, this is my first year boating and design of a cradle is something I would like guidance in...
13 ft beam... if I knew where to start I have the equipment to build but not sure how to do it...
I can get the cradle out from the other boat from my club, I just need to float a forklift down there and 3 hours to unbury it, just thought if some one here had a plan for me it would save me the trouble and trucking to figure it out
rooferdave
rooferdave wrote:during haulout approx 200 boats are hauled out in one day with 2 640 tonne cranes, there is 1 expierienced swamper and a bunch of designated haulout crew from the club. They do not have the skills to set up stands and so must have premade cradles to drop the boats on.
As I reread this it does not sound how I meant it...let me rephrase
Michael thank you and I will look at the other trifly in the club for its sling points and this is a great start as to where to put the uprights
as I was doing the math on how many boats in the club it is probably closer to 150 boats and it seems to be a long day for all involved, I guess as the chance of error is pretty good with all the boats on one day and also they are about 1-2 feet apart and layout is done 2 weeks early I guess cradles are their way, some of the long time members (not many) are grandfathered in with stands from before the rule
Pat... the adjustable part sounds appealing how was this accomplished? do you have a picture? As my boat is in the water the width of the supports at the sling points as Michael suggested will be tough.
A clever guy would have thought of this in the 12-14 weeks it was at my shop on stands! I guess I was wrapped up in trying to get it running and launched :roll:
also for what it is worth our parking lot that we store the boats on is gravel and to boot it is landfill that sinks 1-2 inches per year... and yes dock repairs are ongoing due to movement :shock:
thanks again for the input guys!... guess I can go back to bed now and fret some more....goodnight all
Dave
seems I slept alot better before the boat :shock:
rooferdave
Big D wrote:If those are the rules then you're stuck. But if it's because the ground moves off season, it's a poor reason for forcing members to use cradles. When done properly and maintained off season, shifting grounds or high winds shouldn't make a difference. Is the place shut down completely in the winter with no staff around?
no we have bubbler crews to ensure the docks are not destroyed and our 2-5 live aboards do not sink, the clubhouse/pub restaurant is open 3 -4 days a week in the winter, however with all the snow and drifting it is near inpossible to get near some of the boats to even check
13footbeam
RooferDave
I will see if I can get some photos for you
Pat
Love my Trojan Boat
Current Fleet:
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
77 13' Pintail
13footbeam
rooferdave,
Here is a photo of the finished product I spoke of. The adjustable stands with what ever size pads you decide upon slip into the 2" square tubes. and the keel is blocked at the cross member according to the desired slope you desire from bow to stern. As you can see, the sides are triple 2`` x 12`s. The bunks are 6`` I beams, the angle iron is 1/4`` x 4`` The square stock is 2`` od. I hope this helps
IMG]http://i395.photobucket.com/albums/pp33 ... cradle.jpg[/IMG]
Love my Trojan Boat
Current Fleet:
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
77 13' Pintail
13footbeam
I think the image should show this time.
Pat
Love my Trojan Boat
Current Fleet:
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
77 13' Pintail
rooferdave
thank you! this is the one for the boat in your picture? On square tubing for the side supports does it not have to get closer on center as you get near the bow or is support not needed? Also what is the distance between the square tubing o/c and distance between the cross mebers, the picture helps a ton!
Dave
13footbeam
Dave,
you will want to measure where the slings are supposed to be set when lifting the boat and place the jacks at this location when building the cradle. Also you will place jacks at the stern on both sides. Basically, you will custom build the cradle to fit your boat, if you need some more beef, add it.
Love my Trojan Boat
Current Fleet:
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
77 13' Pintail
13footbeam
One more thing, your keel does a lot of the support work, your jacks are mainly to level and stabalize the boat on the cradle.
Love my Trojan Boat
Current Fleet:
63 25' Owens Woody
76 20' Welcraft
76 9' Whaler
77 13' Pintail
