I have a 1985 10 Meter sedan bridge. I have a leak that is coming thru the bulkhead just aft of the galley and runs thru and then in front of the bulkhed forward down the port stringer and enters a weep hold in hatch in galley and drops down into forward bilge just in front of the head. It is salt water and seems to activate when boat has been run. We have searched high and low with no luck. Appears to be an insert laid glassed on to the hull and i am thinking it may be running under the insert. Any one out there with any ideas?
David dwg4201@cox.net
Frustrating Leak in a 1985 trojan 10 meter
David Gray
San Diego California
On our 1983 10 meter flybridge/aft cabin the louvered vent on the starboard side on the main salon went nowhere and all it did was allow water to leak into the boat. You might have someone run a hose in the direction of the vent while watching it from inside. A friend of ours with a 1987 10 meter had the same leak.
Wes
Wes
10 meter leek
Thanks Wes, The boat is in salt water and the leak is salty so dont believe it it coming from above. But I am interested is what you have to say. Under my starboard vent is a sliding door storage. Everytime it rains, it gets wet. What did you do to solve it?
David
David
David Gray
Hi David,
I hope I've solved it. This winter I pulled the vent and glued a piece of plexi to the back of the vent after I had mounted 4 regular hose nozzles to the plexi. I'm planning on running 4 pieces of regular garden hose from the back of the vent down to the engine room since originally that vent was supposed to provide air to the engines. I have been having a problem with the starboard engine when first throttling up and I'm thinking that maybe it was getting starved for air. If this doesn't work I'm afraid I have to replace the fuel pump. Bummer.
I have a lot of work to do to our beauty before she's relaunched this Spring. I had the bottom sand blasted and have 7 coats to put on the bottom when the weather warms a little.
As far as the salt water goes, if you get any spray over the deck it could get into the vent also.
Good luck and keep in touch. My regular e-mail is DiLuna@aol.com.
Wes
Wes
