Well I had enough of my unreliable old Onan Genset and after a bunch of research I went wilth the Westerbeke 5KW low profile genset. The MFR has been around for 68 years and that was a big part of my decision.
It will be finished on Monday but I thought I'd share the picture. The size difference is amazing !! and the thick red paint looks like it was dipped on. I dont think it will be rusting out lke my Onan anytime soon.
I'll followup when it's done..
Patrick
No mo Onan
Looks great!
That WB looks great. My old Onan 3.0 MDJA Diesel One-Lunger (No lunger!) genny is a loud, unreliable beast.
Which WB did you get? Gas or Diesel? Cost?
What boat did you put it in? Looks like you have it against the forward engine room bulkhead?
I like it a lot!
I like it a lot!
update
Damm, ran into one issue. The new Westerbeke requires 2" input and 2" output. So that means a new strainer, new Wet-Exhaust and an new thru-hull out the side. (1/4 difference from the old Onan setup) Oh Well... didnt count on that but the end result will be worth it...
To answer your questions,
1. The generator was $5500 a low profile gas 5Kw generator ($800 discount in there too)
2. Mounted to the rear of the engine room bulkhead.. ( the old Onan was barley an inch below the floor-board and used all the space between the stringers, so theres quite a difference in size )
Anyhow, having some other things done but I should be back in the water this weekend.. Wish me luck... ! I'll follow-up when done..
Trojan 11 Meter International (87)
New Twin MP 502's 8.2
Westerbeke 5KW
Oceanside Harbor San Diego
Westerbeke 5KW
