front window replacement
They put some serious urathane on these frames. The interior trim is screwed in from under the outer frame, kind of senceless to me. My interior headliner was under the trim. Why should you have to fully remove the outer window frame just to properly replace a cabin headliner? hmmm strange. Well I have 2 good frames ill store if anyone ever needs them.
second one is always easier, took about an hour to get both out. not a bad after work quick project.
- Commissionpoint
- Commissionpoint
Doin' good Jeff thanx. Been hiking a lot. Check my picassa for photo updates on that topic. Here some to get you started. https://picasaweb.google.com/1060575514 ... teeth32112#jefflaw35 wrote:hey MIke!! how have you been? Im gonna glass it in. Off shore fishing alot I hope and I have taken a boat under a swell before personally. Its very scary. and I do beleave these windows would give out killing all my cabin work, so they are going to have to go.
I think it should look just fine if you glass that area in. I've 'submarined' a few swells in the workboat before, and I know what you mean. Its definately a little spooky to have them coming over the windshield on you. Worse still when you have an 8 pointer tied down on the bow and it washes over the gutted carcas before dumping on you.
Keep up the hard work. It will pay off in the end. Looking forward to more updates.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
The windows are very strong, I have accidentally had my 300lb carkiss step on my old one with no problem. That aside , these are not blue water boats.you do not want to venture out if the forecast calls for even a remote possibility of seas rough enuff to stuff the bow. Does that make scence?
MY CURENT FLEET
2003 KEY WEST 2020 WA
1978 ASHCRAFT 14' SKIFF
