Shower Renovations
Shower Renovations
Well its finally time fo me to start some of those projects that i have been planing for before i redeploy next month
i finally got tired of looking at that mangled shower of mine so after a short trip to lowes and picking up all the material i started tearing into it
I purchased new plywood as before i even started i knew that there will be rot since the floor tile was obviously leaking....as you can see in the pictures my thoughts were proven true and i need to replace a good chunk of the side wood and then the whole floor.
The PO decided it would be a good idea to put Formica wall coverings in the shower that started bubbling and thus needed replacing, also puiit a cheap tile on top of what looked like the original tile down below.
I purchased two sheets of 4x8 fiberglass board for the walls, all the sealants plywood nails and what not for the walls, also a new shower pan liner to prevent another leaking issue, i think im going to keep the actual drain pan since i cant seem to find another one to replace it otherwise i would.
the ceiling is going to be removed as well since it is just a painted piece of wood, it will be replaced with a nicely finished tub (the drain pan from the top deck) plexiglass roof and lights between all this since the shower area is all dark
all in all the whole material including new floor tile ran me about $250
Im going to continue demolition tomorrow since it got dark fairly quick today and then hopefully start the actual floor reconstruction and the ceiling before the end of the day.
also ordered a new shower sump system to replace that loud and obnoxious pump that makes loads of noise that was originally there so if anyone wants it i can can ship it to anyone (just pay for shipping, it works perfectly fine)
1974 F36 Tri-Cabin "Jorallyn"
- alexander38
I see lots of Resin in your future ...
- alexander38
what is sealed with ?... and rubber front side understand. What about the backside ?
Re: Shower Renovations
After some bad weather and a few setbacks the shower is finally complete
Very nice. I like. Is that just regular shower stall panels you can buy at Home Depot?
Home Depot didn't have anything at all that came close to this unfortunately,
Lowes had the stuff that i needed so i jumped on the opportunity
$175 for the modular stall, plus about 100 for the faucets and the plastic, some caulking spray paint, prepwork with a new frame and floor
all in all about 400 worth of material and two solid days of messing with and thats the result
abviously everything underneath is epoxied for water tightness, the only "non marine" thing i did was the tile, i put it ontop of flexbond, figured it would work a bit better then glue and will still allow for expending and contracting of the plywood around it
Thanks. Nice job.
It looks great, and very clean, nice job!
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
NICE !!
Huge difference! You did a great job!
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
- alexander38
Sweet !
Are you for Hire? I have the exact shower that needs a make over!
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
- Stripermann2
Very nice work there! Thanks for sharing your project with us!
