Suggestions to tow a PWC?
- Longshanks
i Just bought my first cruiser (76 Trojan tri bridge) but i want to bring my PWC on trips as well. Does anybody know a way to do that without having to spend thousands on new hydraulic hardware? I contemplated towing with a rigid arm attached to swim platform but i've read some posts that say its hard on the PWC.
Perry
1976 F36
Ottawa
1976 F36
Ottawa
Re: Suggestions to tow a PWC?
What kind of PWC? do you know if the manufacturer has a recommended method of towing? look in the manual
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
What speed? two lines attached to the aft corners will be fine. If you are planning on getting on plane, thats something completely different.
i've used these for years. http://www.towdster.com/ I installed two SS U bolts to the outsiide edges of my swim platform that I clip this thing on to. Simply, works well.
The best part is that if you stop quick, it deflects what you are towing off to the side vs crashing up into the back of your transom.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
Very interestingLandVF36 wrote:i've used these for years. http://www.towdster.com/ I installed two SS U bolts to the outsiide edges of my swim platform that I clip this thing on to. Simply, works well.
Hows it work at speed with a V hull ( they used a pontoon ) ? Rough water ?
I like that towdster!!! but I dont think it would work well on a plane with it that close, i tow my 12ft twender about 20 feet off my swim platform, probably more, it rides in the wake nicely there, bounces around and rolls too close, id have to measure the line i made specifically to tow it to be exact
- ready123
This is classic whaler behind my F32 @ 20 mph.... line from each aft cleat.
On plane, tender should ride on the back of the second wave back of the transom.
Paul, mostly I've been dragging along a jetski or a 15' "dingy". At 6-10 knots, you really don't know its back there regardless of the seas (although I should point out that being trapped on the Mississippi, getting 2-3 footers is even pretty rare. Whats more common is some jack-wagon passing you throwing a single 4' wake and coming in closer than 20' when doing so. In any case, these things are bound together with bungie lines so it gives and returns the boat nicely to center. Just once when pulling the kids Jetski do recall running on plain and as long as you kept the ski "climing" the first wave behind the boat, its fine. If its falling off a wave, it tends to push and ride up and then the sticks will naturally push it to port or starboard.
One other comment, if you are towing a craft with an outboard, lift it out of the water and it tracks easier + its not so hard on the outboard.
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
I rarely tow the rib and when doing so it seems to get squirrely at or above hull speed I can't even think about planning .It may have to do with being stern heavy ( heavy OB) But that's no big deal if I am going any distance up on the bow it goes .
Yep I agree, thats the rule, been doing it that way for years.......works great and the dinghy or whatever you tow is very stable.........you can get away with the back of the first wave for short calm trips at hull speed.....captainmaniac wrote:On plane, tender should ride on the back of the second wave back of the transom.
26 knots no problem, 12ft Center Console Rib
yellow floating line with a loop to slide between a dock line going between stern cleats
- lawyerdave71
OK I have a stupid question - what do you do with your tender when you are docking? Do you tie it up to a side?ready123 wrote:This is classic whaler behind my F32 @ 20 mph.... line from each aft cleat.
Captain Dave -
1978 F30 Flybridge Express
- lawyerdave71
Also, how long are the lines that all of you are using?
Captain Dave -
- ready123
My marina has a dinghy dock. When I visit other places I put it where the setup has space, alongside, bow, stern or it's own slip.
My engine is down when towing because it is a 40 HP and really too heavy for that whaler, so it does not clear the water when lifted and therefore is worse than fully down.
Line lengths are adjusted to suit the second wave and can vary with speed and sea.
