trim tab question
Re: trim tab question
prowlersfish wrote: Wed Jun 27, 2018 6:43 am Still could have some growth on the running gear . Do you know what size props ? Also check the tachs . While it should run faster then 20 there is no way it should be doing 20 at only 1800 to 2000 rpm . tachs are off or someone has put way to big of props on it .
btw your putting one too many 0s on your rpm numbers :D
I may add at 20 you should be around 3000 rpm or so that's why I ask about the tachs and props . How are you checking speed ?
hammerhead
Post by hammerhead »
OOPS
hammerhead
prowlersfish wrote: Wed Jun 27, 2018 7:17 am
gps unit
