Oil Change
Allen Sr wrote:
mitch wrote:Ya will not like my way. Top mounted oil filter, remove filter, 5 gal bucket underneath, start engine, 30 seconds oil stops, stop engine, easy fix.
SHORTENED engine life also!
You got that right . thats 30 seconds with no oil going to the bearings and the rest of the engine and you run the oil pump dry every time . Thats a really bad idea
todd brinkerhoff
Post by todd brinkerhoff »
rooferdave wrote:p.s. before you screw on the new filter, put a bit of oil on the rubber gasket! While I am babbling consider a product such as slick 50 at this time
What are the advantages to Slick 50? Product has been around awhile, but I haven't heard anyone who swears by it.
Surely you jest...? :roll:
You have a nice looking boat and I can't imagine anyone being that lazy to not do it properly to protect such an investment.
mitch
Post by mitch »
ok
Torcan
Post by Torcan »
mitch wrote:Yes. all are right. Next time your engine sits for 30 days, count the seconds it takes for oil pressure to come up. I'll start, lub the engine, then dump. Next time I'll count the seconds, bet it's less then 15 seconds. Yes I am wrong.
Hardly the same, but hey, it's your boat.
http://www.cbyc.ca/
mitch
Post by mitch »
ok
mitch
Post by mitch »
ok
mitch wrote:Surely you would agree, if only the starter motor was used to rotate the assembly, until the monument the oil was empty, zero crank/rod bearing contact would be made. Therefore,
I am right again?
Go ahead and overheat the starter motor while you're at it...
Mike Kulp
Post by Mike Kulp »
WOW Thats all I have to say!!!!
Mike 1986 10 Meter mid cabin
mitch
Post by mitch »
ok
Mike Kulp
Post by Mike Kulp »
As far as Slick 50 or any other additive ( This is just my opinion ), just use a good quality oil and change it at the required intervals. I have never seen any manufactures that endorse additives in there engines but they do require specific oils, with that said there is a product called Lucas that the used car dealers use that I poured into a 302 ford one time with a rod knock and it went away at least for a short period of time, so additives may do some good depending on what you are doing. If Slick 50 or STP makes you feel good keep on using it, certainly will not hurt.
mitch
Post by mitch »
ok
mitch wrote:SHORTENED engine life ? Assume you are referring to main bearing and/or rod bearing premature failure? As implied, oil is supplied first, a coating of oil remains under a no load condition at minimum rpm. Careful review, will show, no bear metal contact.
any time the engine is running there is a load on the bearings . yes there is a oil film on the bearings and that will protect it on start up for the second or so it take to get oil pressure .. but running a Engine to pump it out ? thats pushing it . Try that in my shop and you will be looking for a job elsewhere .
mitch
Post by mitch »
ok
jefflaw35
Post by jefflaw35 »
if you guys dont mind, may I ask what oil would be best for a chrysler 318? brand and weight? thanks
