Bucket list for your boat
- vabeach1234
Bucket list for the Paula Sea:
Part A)
a. Fix soft spots on Port side deck.
b. Redo hardtop. Previous Owner didn't do a permanent fix in my opinion.
c. New fuel tanks.
d. Paint top sides.
e. Full Canvas enclosure.
f. Install Autopilot
g. Convert to Yanmar or Cummins Mercruiser Diesel. (Will never happen but it's nice to dream)
Part B)
a. Meet up with everyone at Solomons, July 15 2011.
b. Do the NC loop.
c. Smithfield Station
d. Spend a long weekend at Bay Creek Marina.
e. Just cruise the bay when ever I get a chance.
f. ICW - Norfolk to Beaufort, NC.
g. Oh and go striper fishing. It's been blowing like crazy every weekend here. Haven't caught one yet this season.
Part A)
c. New fuel tanks.
d. Paint top sides.
Part B)
b. Do the NC loop.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
Rossjo Generator
Rossjo, Your generator problem looks like it could be the R-2 or R-3 resistor (hopefully) but I suspect it is in the generator field. Start the generator and release the start switch while measuring the voltage at the S-1 terminal on your start solenoid. The generator should be outputting voltage to latch in the K-3 and K-4 relay. If there is no voltage the problem is in the generator shunt field circuit I think. If you do have 12 volts DC then one of the resistors is bad.You can also check the AC voltage output while the generator is starting to see if the generator is the problem. It should output voltage while starting just will not be full voltage untill generator gets up to correct speed.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
Re: Rossjo Generator
I'll have to print this out and try it ... so - you don't think she putting out voltage?davidsmith wrote:Rossjo, Your generator problem looks like it could be the R-2 or R-3 resistor (hopefully) but I suspect it is in the generator field. Start the generator and release the start switch while measuring the voltage at the S-1 terminal on your start solenoid. The generator should be outputting voltage to latch in the K-3 and K-4 relay. If there is no voltage the problem is in the generator shunt field circuit I think. If you do have 12 volts DC then one of the resistors is bad.You can also check the AC voltage output while the generator is starting to see if the generator is the problem. It should output voltage while starting just will not be full voltage untill generator gets up to correct speed.
I was suspicious of R2 (charging level adjustable 0-6ohm, 150W resistor) , but don't even know where R3 (decompression solenoid fixed value (?ohm) resistor) is located. Have to trace both down. My diagrams don't show a value for R3 ;-(
vabeach1234 wrote:
Part B)
b. Do the NC loop.
. Smithfield Station and Bay Creek Marina. great places we enjoy going there
To Do:
Replace cabin floor joists
Repair soft spot on stbd bow deck or just dig in and do the whole deck
Restore topsides shine
Everthing else is pretty much done
To Go:
Another canal system trip, this time to Lake Erie and both Cayuga and Seneca Lakes, Champlain, and then down to Da City on the Hudson.
To Go:
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Meet Up VD.VA.DC
Am I to understand that it is going to be July 15 on Solomon Island? I should be ready by then. What do we bring?
prowlersfish wrote:Your Boat ,your fammly, food and drink ( for you and your crew) and what every you want to bring .
Nothing cast in stone but I would say its a farly safe bet
Isn't there a $300 initiation fee???
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Thanks to wowzer, I'm adding LED lights to my list
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
rbcool wrote:prowlersfish wrote:Your Boat ,your fammly, food and drink ( for you and your crew) and what every you want to bring .
Isn't there a $300 initiation fee???![]()
Ron
Yes Ron every one here has paid but you I Sent you a PM with the info on where to send it I will deposed it in my fuel tan.... I mean the Trojan escrow account.
The check is in the mail
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
to do list
1) bigger boat
2) radar
3) start remodel of cabins, replace carpet and 80's covering's in V-berth
4) start replacing port-lights and hatches.
5) replace black canvas with tan ( anybody got 10k )
6) buy more toys for the upper helm like VHF with hailer and tachometers with flow meters
part B
Use it more than I did this year, We're layin' out at least 3 10 day trips for next yr. and a few 3 to 4 day ones ( Got lucky Wife enjoyed the NC loop trip alot, something about quality time with me
and meet more of you guys !
1) bigger boat
2) radar
part B
ha ha ha ! Now go clean your boat !
