ENGINE START SWITCH
NOTHING ELSE MATTERS
ENGINE START SWITCH
Post by NOTHING ELSE MATTERS »
Hello, anyone knows what kind of engine start switches are on the 9 meter and maybe all the other Trojans?
I do not have key for ignition on, just a switch for each engine.
Looks like the switch is OFF-ON-MOM.ON but what kind is it?
Thank you.
Re: ENGINE START SWITCH
Its a off-on-momentary on switch , not sure what you mean by what kind ? If you need one check with Bob at Beacon marine
SPST OR SPDT OR DPDT
NOTHING ELSE MATTERS wrote: Fri Oct 19, 2018 9:57 pm SPST OR SPDT OR DPDT
Non of the above the SPDT and the DPDT are normally on-off-on , the SPST is on off . You need a Off / On / Momentary On . it could be single or double pole but you would only use 1 pole . I have seen them called off-on-start before but the right name is Off / On / Momentary On
https://www.trojanboats.net/zencart/ind ... ts_id=1477
