Fuel pump
Posted: Thu May 29, 2008 1:08 pm
Ok you all know that I am the dummy that mounted the electric fuel pump to the deck support stringer
. Now what do you think if I were to use rubber mounts to dampen the vibration sound. Do you think it could work harden the fuel line, and cause it to crack.
The fuel line feeding the pump is about 12 inch long coming from the filter,(that is also mounted hard to the same stringer). The output of the pump is a hard fuel line that can flex, and is mounted to the regulator, that is mounted hard to the engin. Any help
