We often get asked about how the top hat thermostat works and is installed.
Here are a few pictures.
Note: Inside the thermostat housing is a seal -- that seal must be in good condition. If not, you will need to replace the housing. We have the Top Hat thermostat gasket and the thermostat housing in stock. Note: In this application, the cooling water will not circulate correctly without the thermostat.
Chrysler Top Hat Thermostat
- Beacon Bob
- 2B6038FF-7C7D-4407-AF96-E846736784E9.jpeg (154.31 KiB) Viewed 65696 times
- 65D53872-6A10-41A5-8AB2-9EFBEFF93491.jpeg (154.44 KiB) Viewed 65696 times
- D036B55A-9308-4A2A-9B01-75517A9D813A.jpeg (98.8 KiB) Viewed 65696 times
- 8229B077-49C4-4001-9738-4D0894D77055.jpeg (136.19 KiB) Viewed 65696 times
- BEA1ADA7-1025-42FC-ADC8-DD82A864F6D5.jpeg (189.6 KiB) Viewed 65696 times
- C2772346-50E2-40B6-A573-F5D68ED21659.jpeg (199.78 KiB) Viewed 65696 times
- BD4BCFDD-06C1-45BE-B92A-AF2AC006E29E.jpeg (211.26 KiB) Viewed 65696 times
- B7374F8D-FEED-47E7-9816-4A378D05C81D.jpeg (154.31 KiB) Viewed 65696 times
- 0F5DB441-63BF-4625-8F39-46DBB024A7B5.jpeg (154.44 KiB) Viewed 65696 times
