Manifold gasket replacement
Posted: Thu May 20, 2021 7:48 pm
Hey gang,
Out of an abundance of caution, I pulled both sets of manifolds/risers off to inspect. 318’s. Checked out OK. I received replacement gaskets from Barr, and am curious if you guys install them dry, or use a small amount of Permatex (or equivalent).
Also, both of my blocks have the last manifold bolt hole bored into the water jacket. Any idea which product I should use to seal it when I reinstall manifold bolts?
Thanks,
B
Thanks,
B
