Good-day all!
Is there an easy way to dismantle the forward bed frame to get full access to the holding tank? The bed slides apart (extends) like most do, but I cannot seem to find the attachment point(s) to remove the top.
Anyone got a tip or two?
Thanks in advance.
1988 10M mid-cabin, forward berth bed disassembly
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
Model 340
1.5:1 Gearboxes
Jacksonville, FL
Re: 1988 10M mid-cabin, forward berth bed disassembly
I don't know if this helps or not
I opened up the sliding doors at the foot of the bed and looked
up towards the underside of the platform
there is a piece of wood on each slider that acts as a stop
my guess is they have to be removed
after that I don't know
I plan on opening mine up after you figure out how to do it
rr
rr
10 meter mid cabin
Once you remove the mattress, all of those plywood/laminate panels unscrew from the top and lift off. Easy access to the tank at that point.
Just re-read your post. Do you mean “full access” like remove the tank or just access to the top?
Bob,Do you mean “full access” like remove the tank or just access to the top?
Just access to the top for cleaning/inspection would be all I want. I did the best I could with reaching in from underneath the bed. Would be nice to get at it from the top. However, I've since gotten derailed with a more pressing issue, bilge blower/hoses...a real mess. I need to sort that out first.
RR,
I'll be sure to get some video or pics at the least for sharing when I get back to that project.
Appreciate all the feedback....more to follow.
Scott
"Speakeasy"
Model 340
1.5:1 Gearboxes
Jacksonville, FL
Model 340
1.5:1 Gearboxes
Jacksonville, FL
