454 OIL CHANGE
Posted: Thu Feb 05, 2009 10:08 am
by S.A.M.
Oil coolers are new to me. Do they have to be drained or does the engine oil drain back into the pan?
While I'm here, another question.
While running the engines and genny, should the 115 battery charger be turned off till I shut down the engines or does the charger recognize the charge from the alternators?
Posted: Thu Feb 05, 2009 10:28 am
by Stripermann2
Don't worry about turning the charger off.
You'll get most of the oil out. Some may still be in the lines, etc. Not much to worry about though. I like to loosen or remove the filter first.
Tip: When unscrewing the oil filter, take a gallon sized ziplock bag ( a good brand) and put over the filter while you unscrew. It'll catch and contain 99% of the oil and help eliminate the mess. Zip up and dispose...
oil changing
Posted: Wed Feb 11, 2009 6:44 am
by duchess
damm i thought i was the only one that used the bag trick I also put a a oil diaper under the filter to catch any other drips
