Winterizing plans...
I just store mine (inboard V-8 ) with empty water jackets. I've heard that some fill with antifreeze/water mix to prevent corrosion. I just don't know if the rubber vanes in my water pump would like that. Never had anything plugged with rust.
I "ran" my SkiBee 4 or five times out of the water. Had to plumb some new gas line after I took the tops off the carbs and had some leaks. It's hard to stretch stainless! Patched in a piece of rubber gas hose--the good stuff. It worked.
My biggest problem is gas. About 20 gallons of 1-year-old or older gas in the tank. I added Sea Foam and a little Marvel Mystery oil last fall, but I don't know how the gas will "keep" another winter.
I bought some Sta-Bil but haven't put it in yet. I don't like to mix snake-oils.
Funny conundrum: I wanted to "waste" 20 gallons of gas tearing around with it this summer, and was thwarted by a transom fix.
Winterizing?
Winterizing?
Guy Strauss
"Das Boot"
'61 SkiBee, 17' Inboard Runabout ski tow
Ford 292 Interceptor (pictured)
"Das Boot"
