Jabsco impellers
Jabsco impellers
Currently I have jabsco impellers in my chrysler 440s. The model number is 920-0101. I am having trouble finding that model online. Anyone know a good source?
________________________
1975 F-36
1993 Pro-Line center console
1975 F-36
might try NAPA auto supply (likely have a marine catalog at the counter, if you can't get somebody to check for you). I'm pretty sure I bought a Jabsco impeller there a few years back for a Chris Craft I owned at the time -- probably would help to have the parts number for your impeller for possible cross reference. You might also be able to get a match searching by engine model, if there is no category for Trojans.
1980 F26, Mercruiser 305
Are you sure that number didn't change to a 920-0001-P? If so, there are plenty to be had...Regardless, these folks WILL have what you need.
http://www.depcopump.com/datasheets/jab ... 0Parts.pdf
http://www.depcopump.com/home.htm
Impellors
Try Defender, they have replacements that are blue in color, can run dry for a while, and are priced right. Give them your engine info. and they will find it. I replaced mine on my 360's over 10 years ago and they continue to perform perfectly. (Boy I hope I didn't just jinx myself), I'm not in yet.
