Removing the Gooey Mess on my Hatch Frames
Posted: Mon Mar 26, 2007 1:15 pm
by Mac32
Hello again gang,
For someone who just joined the forum Ill bet you are allready tired of all my questions, and Guess what? I am holding back quite a bit considering there is a F32 hull with no interior, window glass, flybridge, and only 8 weeks til the official boating season is upon us. Nobody freaking out here.....gulp.:shock:
Stringer tear down going good, (Ill post pics if anyone wants) so the wife pulled the hatches and frames to start refinishing and take care of a little delam on the deck.
The hatches were bedded either from the factory or in later years with what looks to be like 5200 adhesive. I need to remove the mess from the teak wood hatch frames. I was thinking of trying Marine formula from DeBond corp. Has anyone heard of this, used it, or found something that wont damage the teak?
Oh yeah also I have some Crazing happening on the acrylic (I think its acrylic) hatches. Has anyone had success polishing these up? I have seen products on the market made specifically for this but am overwhelmed with the selection.
Pics
Posted: Mon Mar 26, 2007 3:44 pm
by JuiceClark
Hey I'd luv to see some pics of the stringer project. We're all proud of ya for diggin' in and doing it yourself. Not bad...right?!
I rebeded my hatches last year. The only way I could get the old 5200 off them was to cut it with a big ol' bread knife. Since it's obviously not coming off, I didn't worry about getting every last bit.
Tony
1981 F-36 in FL
Posted: Mon Mar 26, 2007 8:00 pm
by chumwithabottleofrum
Mac-I'm not real familiar with the hatches on an F32-I have an F26. The F26 had "opaque" fiberglass hatch that made the boat look older than it's age-which was approximately 25 years. I purchased a great book-"This Old Boat"-by Don Casey. He has a design in it for overlaying old hatches with new plastic-acrylic, or preferrably polycarbonate.
Can you take your hatch apart to access the acrylic sheet?-If you can you should consider just replacing the plastic-plastics do tend to brittle with age so you may end up replacing at some point anyway.
Also-stay away from acrylic-spend a little bit more and go with polycarbonate. It is tougher, and not quite as prone to scratching. (I also replaced the acrylic in my cabin windows with new polycarbonate. I used the old plastic windows as patterns after I had removed it from the frames). The new plastic really dressed the old gal up.
Posted: Mon Mar 26, 2007 8:03 pm
one other thing-removing a urethane sealant-pretty tough to do. You may try nail polish remover, methyl ethyl ketone and methylene chloride (if you can find it) in that order. Methylene Chloride is very harsh-it is a suspected carcenogen(sp?) so use chemical reisistant rubber gloves and an air cartridge respirator if you work with it.
Posted: Mon Apr 09, 2007 10:33 pm
by Mac32
Ok, I found a few things that work. Debond 2012, found one small can left on the clearance table at west marine. Tiny can for $12 worked good, says it breaks down the molecular bond??? seems to work well though .
The other thing that works equally as well,,,,,,,,Acetone..... I am using it on teak, not sure what it will do to fiberglass but for the price vs volume, this is the way to tackle the goo.
