Page 1 of 2
F32 Wiring.
Posted: Wed Dec 28, 2011 12:46 pm
by Islanddr08
Hello,
I've been discussing my project boat and had great responses, but feel I should be more detailed in my subjects to help others.
I'm going to attack the wiring next. My boat has been disused and poorly serviced for the previous 3 - 5 years before my recent purchase.
I tried to get the running lights going and having some trouble. I get the white running light working and the anchor light from the switch but seems like poor power to the bow. My port and SB lights don't come on. I tried changing the bulbs and cleaning the connections, no such luck. My windlass also does not respond to the switch. The cabin lights work in the bow, so I know there is power going that way, but may have a short or broken wire. Any suggestion as to where to look before I start pulling panels out.
I'm also not getting power to the trim tabs. Not experienced in working these so don't even know where to start. I saw on a purchase manual that there is a fuse behind the switch, don't want to start pulling and tugging on wires until I have a fairly good Idea of how to trouble shot.
All recommendations accepted. I will start in a few days.
Thanx.
IslandDR.
Posted: Wed Dec 28, 2011 12:57 pm
by Stripermann2
Keep in mind, especially with a boat out of commission as long as yours has been, poor connections, dirty/poor grounds will make up the majority of your issues.
Do you have a wiring diagram? That's a good start. Then you can start checking power and grounds, voltage drops, etc with a multi-meter. You need a understanding of how the system is set-up and it's power and ground locations.
I can fax you my diagrams but they will most likely be different than your year. I think Ross may have what you need?
Posted: Wed Dec 28, 2011 1:16 pm
by Islanddr08
I agree on the grounds. I have a meter, but not too skilled in using it. The diagram would be helpful. I have a 1975 F32. It may be a little different, but would not be too far off. It would be helpful.
My fax is 305 688 7872
Robert
Posted: Wed Dec 28, 2011 1:21 pm
by Stripermann2
Okay, I'll fax them over. At least you'll know the layout although your breakers and switches will differ.
Posted: Wed Dec 28, 2011 1:32 pm
by Islanddr08
Thank you. Do you have a contact for Ross?
Posted: Wed Dec 28, 2011 1:57 pm
by Stripermann2
He'll be around shortly or click below his name at the bottom and PM him. Did you get the faxes?
Posted: Wed Dec 28, 2011 2:19 pm
by Islanddr08
Thank you, got the fax. It was poor quality, probally my printer, but from what I did get looks like chinease to me. I'm not chinease by the way and no offense to anyone, I'm sure they'll understand.
I will contact Ross, but have to go out right now.
Thanks again,
Rob
Posted: Wed Dec 28, 2011 2:40 pm
by Stripermann2
Posted: Wed Dec 28, 2011 4:07 pm
by Islanddr08
Very Nice. I guess I have some homework to do. These should be very helpful. It looks confusing, but I'm sure when I get to it, I will either burn a plug in my brain or figure it out.
Thanks,
Rob
Posted: Thu Dec 29, 2011 11:14 am
by rossjo
Good morning - I see you al found my 1972 wiring diagrams.
Does anyone else have ANY wiring diagrams for other years?
It would be GREAT to post them here. Perhaps another sticky at the top for Wiring Diagrams? I'll be glad to host the files, and manage the sticky.
Posted: Tue Jan 03, 2012 9:49 am
by willietrojan
Let me know if this helps, if you cannot see it let me know and I will email mail it to you.
F32 Wiring.
Posted: Tue Jan 03, 2012 9:59 am
by Islanddr08
Thnks Willie,
Can't really see it. Tried saving and reopening with no luck.
Robert
Posted: Tue Jan 03, 2012 10:59 am
by willietrojan
Islanddr08,
I sent you a PM
Posted: Tue Jan 03, 2012 11:46 am
by rossjo
Is that the same as this Trojan Drawing # 55-293 "Diag-12-115V-Hull-F32" Dated Nov 15, 1972 ?
http://RNR-Marine.com/Trojan/Trojan_Dwg ... 2nov15.jpg
Posted: Thu Jun 07, 2012 9:01 am
by katprice
Is there a 55-292 diagram? Need info on the bilge blowers
