10 METER A/C
Posted: Mon Jun 11, 2007 11:06 pm
by WALTER GURAVSKAS
JUST PURCHASED A 1984 10 METER EXPRESS, TURNED ON THE A/C FOR THE FIRST TIME, IT RAN A COUPLE OF MINUTES AND THEN SHUT DOWN DUE TO LACK OF WATER DISCHARGE, INSTALLED A NEW PUMP . WENT TO THE CONTROL NOTHING !! NOT EVEN A CLICK. THE OWNERS MAN . SAID TO PRESS THE RESET SWITCH SEARCHED HIGH AND LOW FOR THIS SWITCH NO LUCK. ANY IDEAS WHERE THIS SWITCH MAY BE HIDDEN ? THE UNIT WAS MANUFACTURED BY AQUA-TEMP CORP. THE LOCAL SUPPLY HOUSE WISHED ME THE BEST OF LUCK TRYING TO FIND PARTS FOR THIS UNIT.ANY IDEAS AS TO WHO MY STILL HAVE PARTS IN STOCK FOR AQUA-TEMP UNITS.ANY HELP WOULD BE APPRECIATED.
Posted: Tue Jun 12, 2007 4:11 pm
by Stripermann2
My a/c unit is powered by the 120 ac circuit breaker in panel. Are you sure it isn't tripped? Sometimes they will trip the breaker on the pedestal on the dock as well. Is the control head a digital or rotory knob set up?
Do you get nothing when you turn on the a/c unit? If so, check power supply first. Also be sure to check that the a/c sea cock is open before you start it up next, maybe it was winterized and shut off before you bought the boat?
Posted: Wed Jun 13, 2007 6:35 am
by RWS
In addition to the breaker on the main panel, the original 16,000 btu Cruisair on my 10 meter did have a trip switch on the compressor system unit that the factory originally placed between the stringers in the engine room. As I recall it was a thin metal tab that would pop out of a small control box and was painted white just like everything else on the unist so it was difficult to locate.
When doing a complete refit in 2005 I replaced the unit and relocated it from the factory location by modifying the shelf where the vacuflush accumulator tank is located and relocating the raw water pump and vacuflush pump.
It was a more difficult job to do these modifications, (not really too bad with the engines out) however the subsequent servicing of all components is easier now as well as moving around in the engine room.
Good Luck,
