F32 Motor Swap 318's, counter rotating?
Posted: Thu Feb 21, 2013 2:28 pm
by K4282
I traded and got a 1973 trojan F32 last December, it has twin 318's, port motor blew (have no idea what but had the heads off it when I got it) and starboard motor was recently rebuilt and runs great. The deal came with another complete 318 suposodly in running condition. Knowing a few things about boats but not a know it all this boat should have counter rotating engines. Now my question is it the motor or transmission, im 99.9% sure its the motor and that they would have different starters, how do I tell on the new motor before I put it in? What happenes and can I put it in if its the wrong rotation? My friend has a 31ft Corsa cigarete boat with twin outboards, non counter rotating and says its ok as long as he doesnt go too fast for too long as the water gets splashed away from the pickups and one starts to run hot.
Re: F32 Motor Swap 318's, counter rotating?
Posted: Thu Feb 21, 2013 2:29 pm
by K4282
on a side note, I pulled the port motor last weekend, its sitting on a pallet untill the snow melts and I can get the forklift over to pluck it off the cockpit
Posted: Thu Feb 21, 2013 2:49 pm
by The Dog House
The starboard engine should be RH and the port engine should be LH. The transmission needs to match the engine (RH engine with RH transmission and LH engine with LH transmission). There are some transmissions that will change the rotation, but the Velvet drives don't.
Posted: Thu Feb 21, 2013 4:33 pm
by K4282
how can I tell when looking at the motor what rotation it is?
Posted: Thu Feb 21, 2013 4:55 pm
by The Dog House
The identification plate where the serial number is should state RH or LH for both the engine and the transmission. I'm not sure how to tell just by looking at the engine.
Posted: Thu Feb 21, 2013 5:20 pm
by K4282
thanks
Posted: Thu Feb 21, 2013 5:46 pm
by 1995 390 express
hi i'm not sure about chryslers but on my gm's the right hand rotation engine has gears under the timing chain cover versus a regular timing chain on the left hand rotation engine. also you could bench test the starter on the running engine to be sure on the one coming out. good luck
Posted: Thu Feb 21, 2013 6:36 pm
by kallen
Does one engine not have a spacer under the distributor. Not sure which one ?
Posted: Thu Feb 21, 2013 7:30 pm
by Big D
kallen wrote:Does one engine not have a spacer under the distributor. Not sure which one ?
Correct. The counter rotator should have that. As mentioned before, look for the engine number plate, it will tell you also. Both distributors turn clockwise. Follow the plug wires, the firing orders for both rotations start at number one plug but the next plug in the firing order is different. LH rotation order = 1-8-4-3-6-5-7-2 and RH rotation = 1-2-7-5-6-3-4-8. Rotation on a marine engine is always referred to by standing behind the engine and looking at the rotation of the flywheel, not the front of the engine as in a car. LH rotation is standard rotation.
Posted: Thu Feb 21, 2013 9:24 pm
by Commissionpoint
Correct. The counter rotator should have that. As mentioned before, look for the engine number plate, it will tell you also. Both distributors turn clockwise. Follow the plug wires, the firing orders for both rotations start at number one plug but the next plug in the firing order is different. LH rotation order = 1-8-4-3-6-5-7-2 and RH rotation = 1-2-7-5-6-3-4-8. If there are no wires, starter etc. Rotation on a marine engine is always referred to by standing behind the engine and looking at the rotation of the flywheel, not the front of the engine as in a car. LH rotation is standard rotation.
Good summary Big D. Someone should copy that and paste it into a FAQ sticky.
Posted: Thu Feb 21, 2013 9:29 pm
by some people's kids
Look at the props and see which way they would spin if u were going forward, that will tell u what way they turn
Posted: Fri Feb 22, 2013 8:15 am
by Stripermann2
This should help. It addresses some older Chrysler marine engines but throughout, mechanical, timing, firing orders, prop rotations, etc will be the same.
http://www.correctcraftfan.com/Download ... Manual.pdf
Posted: Sat Feb 23, 2013 9:32 pm
by larryeddington
I have pics of 318 counter and regular, posted in here somewhere, and spacer is under distributer of counter or RH rotating engine. RH refers to looking as flywheel end. I also posted pics of the gears the gears viewed from top of block down ditributor hole, here you go:
http://www.trojanboats.net/wforum/viewt ... ion#p55944
Posted: Sun Feb 24, 2013 1:10 am
by Big D
Here are a couple of good drawings to help with stater selection based on position and engine rotation.
http://www.jamestowndistributors.com/us ... docId=1095
Posted: Mon Mar 04, 2013 12:49 pm
by K4282
i kind of forgot about the spacer thing but i had removed the starter as you need to anyway to pull the motor and the new one (used) is on a pallet with a bell housing and starter, i gave them both power and the starters crank the same way, score the motor is the right one
