Generally speaking, changing names was an old superstition among commercial vessels of the time. I don't think they apply to recreational vessels.
You might try a heat gun or hair dryer and CAREFULLY heat and peel as you go. Be sure to remove any and all adhesive, best as possible. Not sure what adhesive remover to recommend. Good luck.
Removing boat name stickers?
At NAPA auto parts stores, they sell a wheel that you mount in your drill. It's about a 5 inch disk, and feels like a big eraser. Its made to take decals off cars (your race car I guess) but I've used them to remove pin striping and lettering from boats many times.
If the wheel doesn't take it off quickly, try (in a test spot first) a little oven cleaner to soften up the letters.
Mitch
Mitch
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
From the picture, it doesn't look as these letters have been on for a long time. My graphics were on the boat for 10 years and I removed them by warming with a heat gun...worked fine. I didn't get my official name change papers from the "Coast Guard Gods" until it was too cold to apply the new lettering, so they will go on in the spring. You may have seen this already, but here is the link for the ceremony.
http://www.48north.com/mr_offline/denaming.htm
Steve L.
"Pauper's Paradise"
Steve L.
"Pauper's Paradise"
When I removed the old painted on name , it did leave a ghost. I buffed the transom with 3m Super Rubbing compound, then with Finesse-it. Applied the new lettering and waxed with 3M Marine wax. No, I'm not a pitch man for 3M products...this is just what works best for me. Oh yeah...I did break down a buy a $200 Milwaukee 7"/9" buffer and installed a 3M Super Buff hook/loop pad. Wow! what an difference. The 6" Craftsman buffer took a $#!+...after I worked it to death. If I have great success with a product or an idea, I don't mind sharing. Hope this helps...
Steve L.
"Pauper's Paradise"
Steve L.
"Pauper's Paradise"
