F32 Sliding Glass Door Panel Removal
I have a project that will require the temporary removal of the starbord sliding glass door panel on my 1975 F32. Can anyone provide some guidance on the procedure and complexity of this task?
I have both fixed panels out of my F-36 now. Don't know if a F-32 is the same configuration or not, but mine came out by removing the inboard frame and sliding the glass out of the other 3 pieces of frame. It's not easy and you'll have to grease up the rubber seal with dish soap or oil, but it can be done. My rolling door is still there...never did figure out how to get it out! Oh yea, don't try to take out the post between the center door and the right panel. It don't come out unless you remove the entire door frame which you do not want to do.
