Fuel Gauge
Fuel Gauge
Hello,
Very new to boating and I just bought an 87 Trojan. Excellent condition of the boat but some of the gauges need to be replaced. Any idea where I can get a fuel gauge for this model? It is an express cruiser.
87 Trojan International
Fiberglass Hull
Fiberglass Hull
Re: Fuel Gauge
Just a thought before I replaced the gauge, would check the tank level sensor as it moves and receives more chance for wear and error. IMO
Re: Fuel Gauge
Thanks so much for the response. That sounds good. Is this something I can do myself? Checking the level sensor?
Fiberglass Hull
Fiberglass Hull
Re: Fuel Gauge
If you ground the wire to the tank it should read full. If gauge goes from empty to full by disconnecting wire then grounding , gauge should be okay.
- The Dog House
Re: Fuel Gauge
Also, the fuel gauge needle should be below "E" when the ignition is turned off. If the needle does not move when the ignition is turned off the gauge is broken.
Former boat: 1971 Trojan F26
Re: Fuel Gauge
i'm sorry this is not always true, some guages maybe but not all. you cannot make this assumption for every fuel guage or any guage for that matter.The Dog House wrote:Also, the fuel gauge needle should be below "E" when the ignition is turned off. If the needle does not move when the ignition is turned off the gauge is broken.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Re: Fuel Gauge
Thank you all for your responses. Though it may not be true for all gauges, is it true for the fuel gauge on the 87 Trojan?
Fiberglass Hull
Fiberglass Hull
Re: Fuel Gauge
have you done the sending unit wiring and check as stated above? thats the easiest thing to do first. if the sending unit fails its test its a piece of cake to change out as long as you have some access to the top of the tank. you need to know the apx vertical measurement of the tank and the one purchased should be in that range the universal ones let you adjust for varying tanks, unscrew the old and install the new. you have a 27 year old boat so who knows if you have original guages in it or something else. to say what action that particular guage will take with power off is hard to say i dont have that boat, but to comment all guages will be at below E when off is not correct, all the sending unit is doing is changing resistance with the level of liquid, the guage is moving in response to that .
heres a link to a moeller sending unit maybe it will help
http://www.moellermarine.com/sites/moel ... ations.pdf
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- The Dog House
Re: Fuel Gauge
Do you know what type (make and model) of gauges you have? Can you post a picture? That would help with your specific problem.vickyb wrote:Thank you all for your responses. Though it may not be true for all gauges, is it true for the fuel gauge on the 87 Trojan?
Faria has a gauge troubleshooting guide at faria-instruments.com/site_manuals/IS0100_D_Quick-Reference-Guide.pdf that may be helpful. They also provide a more complete repair guide at faria-instruments.com/site_manuals/IS0100_L_Warranty_Repair_guide.pdf that should help.
Re: Fuel Gauge
Is changing of fuel senders something that is a DIY? Has anyone (who is not a marine mechanic) done it themselves?
Fiberglass Hull
Fiberglass Hull
Re: Fuel Gauge
you can google this and many questions you may have get lots of answers to these types of things
done this on a couple of boats i've had its very much diy
heres a video on youtube shows you whats involved as long as you have access to the top of your tanks its a piece of cake
if you dont like that one theres plenty more
http://www.youtube.com/watch?v=K0CsX4Xu450
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
