Getting the Onan Started
bjanakos
Post by bjanakos »
My new to me 78' F32 is equipped with an Onan 6.5 genset. I am told that the previous owner had not run it for possibly more than a decade. I have no reason why, but to be honest, there is not much need for a generator on a fishing boat.
It's nit the highest priority, but I am curious if I can get this thing fired up. I'll start by replacing ignition parts and cleaning out the carb. I would probably try a compression test, but I am worried about the rings. Should I spray some PB blaster in the spark plug holes ans let is sit for a a few days?
Otherwise, what else to look for before turning her over?
Allen Sr
Re: Getting the Onan Started
Post by Allen Sr »
If you are going to put anything in the cylinders use Marvel Mystery Oil not PB blaster.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
X2 on the MM oil
Post by larryeddington »
So you do no harm before getting it to run take the belt off of the raw water pump. Assuming you get it started you will not want fragments of old impeller all over the water system. I posted an article on my journeys with getting my 6.5 up and running. Many of the parts are very spendy, example the bearing and shaft assembly are over $400, I made mine which is explained for about $160 and $29 bearing. Also the electric choke pull off may have seen better days also about @120. Mine now works perfectly and starts instantly.
There are article on the net on how to convert to electronic ignition using parts from the RV version of the 6.5. I have not done that as yet and won't until need arises.
bjanakos
Post by bjanakos »
I will look up your article (if you posted it here), but if you have the link off-hand, it would be much appreciated.
Should I figure on just replacing the impeller first before turning it over?
My article for making a bearing, and using different pulley.
http://www.trojanboats.net/wforum/viewt ... ing#p78740
Electronic Ignition is here:
http://www.smokstak.com/forum/showthread.php?t=50493
bjanakos
Post by bjanakos »
Thank you!
