I have a water leak that is stainning the bottom of the kitchen cabinets. The water is running from the bottom of the kitchen cabinets to one of hatches in the galley.
I have a 12M and had a similar leak. Water was leaking from the the vents for the galley and the head. I ended up having to take apart the inside of the cabinet and cur out the inner fiberglass behind the blowers because of rot
Yesterday I took the blowers out and there was not much rust on them due to water. The vents on the outside are are in bad shape. I am thinking of replacing the vents and adding clamshell vents.
