Teak wood deck replacement?
I have a 1969 36' Trojan Tri Cabin. The sub-deck under the teak of the forward and aft deck is rotten in a few areas. I am looking to have it replaced including the teak or to replace the sub-deck and have it glassed over. Any recommendations? How much would a job like this cost?
Re: Teak wood deck replacement?
I can't help with a cost or who, but I've been working on my aft deck that was completely rotten. After rebuilding the frame or sill, I covered 3/4 plywood with resin, glued and screwed it in place and put 3 layers of glass on top. Teak would make a nice floor but I'm planning to use marine vinyl
https://www.allvinylfabrics.com/Marine- ... /1267.aspx
It was a big job...I don't recommend it
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
Hi Barrie,
Are you planning to put drains and scuppers in or does the deck drain a different way? I have no experience with a Tri Cabin, so not sure what I don't know.
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Sorry ryankla, didn't mean to hijack this thinggitchisum wrote:Hi Barrie,
I did reopen the 3 factory deck drains and inserted pcv tube as a liner, kind of bedding them in. You can just make out one opening in this picture.
I added hatches so I could lift engines and stuff in and out
I have yet to add the bilge vents and shore power and water
Barrie
Not sure where you are but, this is where you can get plydeck in my area. www.condonlumber.net
seavoyager36@hotmail.com
"Restless"
"Restless"
