F-32 Cabin Vinyl
Posted: Sun Apr 24, 2016 6:50 pm
Our F-32 is suffering form the common problem of wrinkling vinyl in the forward cabin around the anchor locker. It appears that the teak plugs must be pulled out of the wood trim to remove the screws on the side panels first. Is that correct? Pull the side panels then the forward panel? I am hoping the ceiling panel stays in place once the forward and side panels are removed, is that the case?
Any tips from someone that has dealt with this?
Thanks!
Thanks!
