slight vibration
PLAYMATE
slight vibration
Post by PLAYMATE »
guy's , I seem to have developed a slight vibration at cruising speed 3000 rpm.
just started , not sure where to look, not sure where its coming from?
any suggestions?
The Dog House
Re: slight vibration
Post by The Dog House »
Did you hit anything? I had a slight vibration that was caused by a slight bend in my propeller. After I had the propeller reconditioned the vibration went away.
Agreed, if this just started, you may have hit something. You may have wrapped a bunch of weeds or a rope around the prop. It could also be that an old strut bearing finally wore enough to cause a vibration. Loose motor mounts and fasteners, rotten stringers, and engine run-ability issues can also lead to a sudden vibration.
