F32 Rudder support beam replacement
Martino
Post by Martino »
I'm in need of pics of the rudder support beams. I have my old pics for reference. I'm replacing the old ones but I'm trying to figure out why there were blocks bolted to the side of the stringers for them to sit on?
Why not just go across the stringers?
Advise and thoughts would be greatly appreciated !
Martino
Re: F32 Rudder support beam replacement
Post by Martino »
You need to put it back the same way so safety collars roll pin will fit into same hole. Rudder port is the lower bearing. The top of the rudder should be 1/8 “ or less before the end of the rudder port.
Martino
Post by Martino »
Looks like I will be purchasing the wire pins and collars.
Thanks Bob
Looks like your doing some nice work .
Martino
Post by Martino »
prowlersfish wrote: Sat Apr 10, 2021 10:49 am Looks like your doing some nice work .
Thanks for the compliment. Stringers and bulkheads are replaced. Now working on rudder system. And also will be having the fuel tanks reconditioned. As for the original water tank it also is getting reconditioned.
