toggle breakers
toggle breakers
Does anyone know where to get a 25 amp toggle breaker like those used on an 84 midcabin? Before you say it, yes, I will check with Bob at beacon.
Re: toggle breakers
bob can get em up to 20 amp
Re: toggle breakers
Blue sea ?
Re: toggle breakers
these are a critical item
when i first got my boat from the original owner I found several of these AIRPAX breakers had been replaced with a toggle switch
DANGEROUS !
DANGEROUS !
Re: toggle breakers
Airpax Maybe if noy do you have a photo ? https://www.amazon.com/s?k=airpax+circu ... nb_sb_nosslarryeddington wrote: ↑Fri Jun 04, 2021 7:47 am Does anyone know where to get a 25 amp toggle breaker like those used on an 84 midcabin? Before you say it, yes, I will check with Bob at beacon.![]()
Re: toggle breakers
bob has them up to 20A. He guided me to higher am ones. as 20 is highest Trojan uses.
