Engines Stalling
Fishblues
Engines Stalling
Post by Fishblues »
At my whits end with this problem and could use some help. 1976 Trojan F32 with Mercruiser 233
Rochester Carbs rebuilt, new coils, new alternators, new water pumps, new plugs/wires, all new senders, switches and gauges, all new fuel in both tanks, etc.....
Ran boat in slip for 45 minutes, sounds great, runs smooth, lot's of compliments on how good they sound. Took the boat out and ran about 2 1/2 miles, ran great, no problems. Put the boat in neutral and sat with them running at idle for a couple of minutes then one stalled and a minute later the other stalled :x
Drifted for about a 1/2 hour and got one engine started and putted back home, engine stalled so I tried the other engine and got that one started and continued on until I reached my slip. Got both engines running as I was pulling into the slip and both stalled as soon as I got my stern between the poles. Thank god as I was able to grab my lines and pull the boat the rest of the way in. Disgusted I just walked away as I have been dealing with this issue for awhile now and am out of ideas.
Any help or suggestions are greatly appreciated.
Brooks
Re: Engines Stalling
Post by Brooks »
I had this same problem, and a few others, that were solved by everything you've done, PLUS replacing the distributor with a Pertronix (I have Chrysler motors).
http://www.marineengine.com/boat-forum/ ... or+advance
Read the link above, check your timing and total advance (and that it advances correctly). Changing out my prestolite distributor for the pertonix solved a major problem. Then I found serious debris in one aft tank, which had to be addressed.
I don't want to curse it, but everything is working great now.
You didn't mention fuel filters / water separators. Did you clean or swap them out too?
Fishblues
Post by Fishblues »
I should have put that in there to. Mallory electronic distributers installed. Just put on new caps and rotors when I did the plugs and wires.
I did an oil change and a couple of weeks ago and put new filters and gas/water separators in as I do every year.
Boppy
2025 Forum Support
2025 Forum Support
Post by Boppy »
Simple question: Did you check the contents of the old gas filters when you changed them? Hope they didn’t look like this
‘77 F26 HT Since 1999
Smileybritton
Post by Smileybritton »
Fuel pumps, check pressure at carb inlet.
buffalobill
2025 Forum Support
2025 Forum Support
Post by buffalobill »
If you have the old distributors, time to consider the Pertronix dist. . I have 360's in our F32 and starboard had issues with stalling. After replacement, NO MORE ISSUES!
If you need a Chrysler 318/360 distributor we have them in stock.
Pertronix Chrysler marine distributor are all back ordered.
https://www.trojanboats.net/zencart/ind ... cts_id=534
oldboat1
Post by oldboat1 »
Might try setting the air/fuel mix a bit richer on each carb.
1980 F26, Mercruiser 305
