1989 10.8 M A/C System
- jfgkahaluu@gmail.com
My raw water pump for the A/C system is not turning on, pump is good. Does anyone know where the relay is for it? Lunaire 16k system. Thanks.
Re: 1989 10.8 M A/C System
Factory system? Not working on both ACs ?
Yes Factory. Raw water is not turning on for either system.
I have run a hose through and the front A/C is blowing cold, main salon A/C needs a charge but compressor kicks on and everything seems to be working just not cold.
Did you check for power at the pump. should be a relay box near the units
Yes, no power at the pump when the A/C is running.
The relay box that controls pumps may be under the dinette.
