Raw Water Pump Ford 302, 351 . (G21)
any have one of these? mine went bad.
Trojan
I'm not sure that's what I have on my ford 351w, I wanted to rebuild it but it`s in bad shape so I can not. I thought if someone had a extra one I could rebuild it.k9th wrote:I have twin Merc 255s which I understand is the Ford 351. My old ones looked nothing like that and I replaced both of them with the new design recently because one of them failed. The new design doesn't look like that either.
Trojan
I may still have the old one that was still working when I replaced it. I am aboard SeaDog right now and will check when I get back. You are welcome to it if I do. I replaced it as a precaution since the other one failed and I wanted them to both be the same age. Easier for a guy my age to remember that way.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
thanks let me knowk9th wrote:I may still have the old one that was still working when I replaced it. I am aboard SeaDog right now and will check when I get back. You are welcome to it if I do. I replaced it as a precaution since the other one failed and I wanted them to both be the same age. Easier for a guy my age to remember that way.
Trojan
If you still have it could you take a photo of it and post it.k9th wrote:I may still have the old one that was still working when I replaced it. I am aboard SeaDog right now and will check when I get back. You are welcome to it if I do. I replaced it as a precaution since the other one failed and I wanted them to both be the same age. Easier for a guy my age to remember that way.
Trojan
if you can will you post where the mounting holes are so i can see how it mounts si i can see if it will fit. i was told there are several models that will work.Rodman wrote:k9th wrote:If I still have it I will post a photo first to see if you want it.
Trojan
Maybe bob could get you one or You could have your rebuilt . Depco over in clear water is a good place to deal with they can rebuilt it or sell you the parts
http://www.depcopump.com/
