Electric Raw Pump
- guglielmo6160
Electric Raw Pump
Before anyone goes haywire,,
lol Has anyone used an electric raw pump,
obvious disadvantages, like making certain it only goes on while the engine is running, etc,, but I really dont like these raw water pumps,, seems there destined to fail,
any thoughts,
any thoughts,
1983 10 meter express
I don't know OK anyone making a raw water pump suited for a marine main engine , It would have to be a powerful pump ,that would take a lot of power to run . Your raw water pump moves a lot of water . A electric pump that big would demand a larger alternator . I believe it would be more trouble then its worth , Marine raw water pumps hold up pretty well just change the impeller once in a while in most cases .
a electric pump has a constant flow .Your raw water pump flow increases with speed as the engine needs more cooling water the fast it runs .
Some small marine diesels generators use a electric water pump . They do OK , the difference ? Its a smaller engine that always runs at the same speed and it has 110 volt out put to run the pump . They use the same pump that is used on a marine A/C unit .
Many,Many years ago my first boat was a Kayot deck boat w/ OMC I/O chevy 350 (260hp) I knew less than zero about outdrives.
Naturaly when I bought the boat it fired right up in the guys driveway while hooked up to a garden hose so I snatched her right up.
My first proud trip out on the Potomac river she overheated teribly, we almost drifted into Dam #4
When I got home I called the closest boat mechanic and he told me about the impeller in the outdrive and quoted me what seemed like a million dollars to fix it.
I decided to hook up a big 12v pump since I didn't know how to fix an outdrive.
Got out on the river and it worked fine....... until I got up on plane for a few minutes then over heated until I came back to idle.
Needless to say, I spent the next three weeks learning how to fix an OMC outdrive. Just one mans story about pride.
p.s. forgot to mention my bitch ex-wife telling me "I told you so" for monthe afterwards
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
- Muskokan345
I think the key word is maitenanace, personally, I change the impeller every 2 years, pretty cheap insurance, I think, cause if your boat overheats, you don't just pull over. Plus, up here in the great whute north they sometimes cicrulate anti freeze for winterizing, I had a buddy store his implller in a jar of antifreeze one winter, well come Spring that sucker was about twice the size! So, I pose the question, how often does averyone change thier impellers?
I have 3 big electric water pumps on the yacht I run. for AC cooling, AC circ, and one for fire. Two of them discharge a solid 3" stream of water so I think you could keep a small V8 cool with one. The problem is power and cost. Mine are AC but unless you have a generator you will need DC motors and a lot of battey power. I am guessing about 10 amps to run one of these pumps. My pumps cost around 1,800 dollars so even if you get a smaller one and spend 1,000 that is still the cost of 2 engine mounted pumps. There's one more thing, these electric pumps still have almost the same pump housing and impeller so any problems you have on a engine mounted pump you will have on the electric one. I have to change the seals, impeller, bearings, and sometimes the whole pump on these electric pumps just like I do on the engine mounted ones.
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
- guglielmo6160
- Sporadic User
Gotta agree with everyone here; someone sat down and designed your cooling system with the engine demand in mind don't think I'd change it.
Ron, I have a "bitch" exwife too; before the big "D" she mentioned I'd never own a boat as long shes around...
Now I have two boats.
1963 31' Sea Breeze; Twin Interceptors
2000 21' Lightning; Marine Power 454 jet drive
http://s1177.photobucket.com/home/sdelfino5225/index
- Sporadic User
Must be why they're "ex"
- alexander38
Ex equals more boat money, with the right judge .
Or in my case I gave up my bike when we had babies, when the last got out high-school we stopped at the HD dealer and before we got out of the car she said wouldn't rather have a big boat
Got both!alexander38 wrote:Ex equals more boat money, with the right judge .Or in my case I gave up my bike when we had babies, when the last got out high-school we stopped at the HD dealer and before we got out of the car she said wouldn't rather have a big boat
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
My Ex told me that she was going to make it her goal to get the F-25 in court. She hated that boat and it was only to piss me off. I said no way in hell, but my boss recommended that I give to her and let her deal with owning a boat that she hates, she will end up dumping it cheap and end up with a lot less money. After I said no problem the boat is yours she changed her tune. Long story short, I kept the 25, bought a 32, and parked both of them side by side at a marina overlooking her office window for a year.
I love it when a plan comes together
Doug
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
summer storm wrote:My Ex told me that she was going to make it her goal to get the F-25 in court. She hated that boat and it was only to piss me off. I said no way in hell, but my boss recommended that I give to her and let her deal with owning a boat that she hates, she will end up dumping it cheap and end up with a lot less money. After I said no problem the boat is yours she changed her tune. Long story short, I kept the 25, bought a 32, and parked both of them side by side at a marina overlooking her office window for a year.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
- guglielmo6160
