buily-in heaters safe ?
jimbo36
Post by jimbo36 »
I have built in heaters that I believe are original factory installs in my 1974 F36 Tri Cabin. :? Anyone else here wondering if they are safe? :shock: I think mine are Chromalox. One on the end of the setee in the Salon and one in the aft cabin in the rear bulkhead behind the folding ladder. Jimbo36.
Maybe , due to the age and what they live thru a close inspection is in order . The one in my v berth had a short in it ( even when off ) I have removed both of them from the power source and rely on a west Marine heater and a oil filled radiator heater . and block heat for the engines . one of the breakers that was for 1 heater now is for the block heaters and the other is now for the fly bridge power ( incl heat )
rbcool
Post by rbcool »
IMHO I wouldn't trust a built in heater more than 20 years old. Many codes have changed since then.
Paul...... you've mentioned west marine heaters several times, do you like them? I guess I mean, would you go out of your way to get one?
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
randyp
Post by randyp »
I use a good old 120V / 1500 watt space heater purchased at Lowes a couple of years ago. Works fine for the F26 cabin on those early spring and late fall mornings and nights aboard. I agree about not trusting a 20+ year old built in heater.
Randy P
1977 F-26 HT
"Blue Heron"
Ron ,
I like them as the hold up well and they are hard to knock over . and thats a plus on a boat . not the cheapest but worth it in my opion . I use a oil filled radator the heater to keep the cabin from freezing but use the west one when on board and need more . I also use one up on the flybrige for cold weater boating .
rbcool
Post by rbcool »
Definitely gonna get me one :wink:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
g36
Post by g36 »
mine still work properly but... i only use my originals when i am physically on my boat and not while sleeping. i also have a fear of something being this old. i have found new heaters that will fit in the original wood boxes (if that is what you have also) that will have todays safety features i.e high temp safety features
i havent spent the money on them but have thought seriously about it. that way the original look would still be there but it would be safe
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
