10 METER A/C
The right location is at home , But if you going to do it anyway I would think the swim platform would be the only place to put it and the hot dry exhaust pointed away from the boat . closed transom for sure
No swimming around the boat when running ( goes for built in also ) This has been a big issue that has cause several deaths
As far as a issue with a built in (marine ) gen gone bad causing issues thats true too . and that goes for the Main engines as well . Fear factor no Safety factor yes.
I take safety of my family Very seriously. Not trying to start the genset war ( again) , But I will never keep quiet on safety . :D
And with 2kw may as well use a inverter as it won't power much.
BobCT
Post by BobCT »
I with on the safety part, no issues there. I would likely run it on the platform, during the day. 2k will charge the batts, run the micro or stove (not at once) and maybe a 12k AC unit.
I don't know if I would even do that but it was in the back of my mind.
1988 10m mid cabin
crazyyankee
Post by crazyyankee »
Lumpy wrote:Yes, I went with the top discharge. I need to really get up in there to investigate the duck work coming down. My original unit "Lunaire" had a 6x12 rubber boot connecting the unit to the "ceiling" which really isn't the ceiling but the top of the area it's in. I'm thinking I might be able to just drop flex duck work right down on it. I"ll let you know what happens. I'll try to take some pics so you can compare.
Chris
So how was the installation? BTW...I sent you a PM.
Our Twitter and our Facebook page.
