propellor removal
manintheconoe
propellor removal
Post by manintheconoe »
Hello to everyone...
I recently aquired an f26 Trojan 1976 ... It has a snapped drive shaft & damaged prop... can i replace both while still in water???
I am very mechanically inclined, aircraft mech in Navy... so, the person just damaged the prop & snapped the shaft,,, is it doable to replace while in water? I have the nuts off prop, the shaft is snapped in the eng compartment,,, rite between trans & where it goes thru hull.??? i can see under water, there doesnt seem to be a pin in prop, tapped on it under water but not coming off. ???
KC
ready123
Post by ready123 »
Yes you can do it in the water... when you remove the shaft wait till it settles on the bottom then it will be more stable to work on. :lol:
manintheconoe
propellor removal
Hey, Thanx for reply....
so should the prop slide off the shaft??? cuz i was was tappin on it with rachet under water & it's not moving...
& is there clearance between prop & rudder??? & will shaft clear the rudder??? or will the rudder need to be taken off???
Ready was kidding , you need to haul the boat . And I would look for other issues , shafts don't break that easy The strut could be bent .You need a puller for the prop , if the rudder is inlined with the shaft then it will need to be pulled ( some are off set )
alexander38
Post by alexander38 »
READY123 YOU OWE ME A PHONE :lol: :lol: :lol: :lol: :lol: :lol: lmao
k9th
Post by k9th »
Welcome to the forum.
Hauling it is the only way.....Ready was pulling your leg for sure.
Tim
"SeaDog"
1979 36' Tri-Cabin
Wow that's quite a hit to snap a shaft. I'd be a little worried about the tranny and the pressure plate too.
