Found a great 318 complete but a question
bkwesq
Post by bkwesq »
The new engine is reverse rotattion is that a problem for my F25? single engine obviously - what do y'all think?
1976 Trojan F 25
http://my1976trojan.wordpress.com
Knot Guilty
Scorpyon
Post by Scorpyon »
As long as your prop matchs your rotation u should be ok
"If you find yourself arguing with an idiot, Be certain they aren't doing the same thing!"
1973 F25 Express Cruiser
"Hearts Escape Too"
bkwesq
Post by bkwesq »
Ok thanks that's all I wanted to know!
1976 Trojan F 25
Knot Guilty
Are you using the old trans ? If so you will need to rotate the pump on the front of the trans .
bkwesq
Post by bkwesq »
Yes sir - I planned on using it. I will look for the pump not sure what that is but I will figure it out
1976 Trojan F 25
Knot Guilty
Look at the top of the forums you will see some manuals .
larryeddington
Post by larryeddington »
in a conversation today with beacon bob the topic of single screw engine rotation. According to bob virtually all single screw applications use reversie rotation engines. According to him either directon will propel but for an engineering reason reverse gives better performance.
Go figure, BTW he said I could quote him.
bkwesq
Post by bkwesq »
I have to get him down here - he is only 30mins away
1976 Trojan F 25
Knot Guilty
myakka
Post by myakka »
My understanding is, it was economy of scale that lead most boat builders to buy reverse rotation engines for the single screw models. I guess I could be wrong.
I have worked on a lot of boats a normal rotation is the norm on single screw boats . and reverse rotation engines cost more then standard
mr elevman
Post by mr elevman »
its my understanding rh rot is standerd rot on ford and chevy but lh rot is std on a chrysler and rh is reverse
