fresh water/closed cooling system
jefflaw35
Post by jefflaw35 »
im looking into this for my 318, since I will the entire boat gutted it seems like a good investment and right time to do it considering I boat in salt water. Any suggestions, pros or cons?? Thanks
Its a good idea , the engine in your boat has it now . If the engine you maybe getting is raw water cooled and been run in salt water it may not be worth it .fresh water/closed cooling engines will run better last longer and burn less fuel as the run at better ( warmer) temp .
jefflaw35
Post by jefflaw35 »
huh?? i already have it? hmmm guess i didnt realize that, but it would explain why the prev owner had 15 gallons of antifreeze on board. motor im getting should be the same, but its coming off of a lake and never seen saltwater thank god. wow that just changed my whole out look, if this motor runs off antifreeze then how could he tell me its seized up from not being winterized? any why is it so seized up. my motor may be good after all
Commissionpoint
Post by Commissionpoint »
It still has water going through it Jeff, its just got a heat exchanger, which is the 'closed' part of the system. If the PO had a bunch of antifreeze on board it might be because the system has some leaks and he had it there so he could top it up. Unwinterized and it will still ruin the engine. From the looks of your pics, you are doing the right thing looking for a decent long block to do a swap with. I realize pics can't tell the whole story, but they do say enough that I think your plan to do a swap is a good one. If you decide to go with a closed system its definately a good idea, as Paul already mentioned. Do expect to have to spend some more money to set it up though. Closed system components are a bit more costly, but worth it in the long run, espescially if you are in salt water some or all of the time.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
jefflaw35
Post by jefflaw35 »
so what i have now isnt completly closed?
Commissionpoint
Correct. Raw water circulates through the heat exchanger and associated plumbing to keep the coolant from overheating. Notice there is no radiator and fan assembly. The function of the radiator and fan is replaced by circulating raw water. Am I making sense to you? I'll see if I can find you a simple diagram to look at just in case i am speaking gibberish.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
jefflaw35
Post by jefflaw35 »
no its makes sence, i just thought the systems i was thinking about didnt use any water from the ocean, seems pointless to spend the $ if your still running saltwater thro it. unless its just the system that uses the saltwater and not the motor
Commissionpoint
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Commissionpoint
jefflaw35 wrote:no its makes sence, i just thought the systems i was thinking about didnt use any water from the ocean, seems pointless to spend the $ if your still running saltwater thro it. unless its just the system that uses the saltwater and not the motor
Exactly. The coolant (antifreeze) goes thru the block, and the water is used to cool off the hot antifreeze after its been through the engine.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
jefflaw35
Post by jefflaw35 »
weird, then why would you have to winterize an enigine that uses antifreeze? that maybe a dumb ??? :?
Commissionpoint
The heat exchanger will get ruined from expanding water if it is left full and it freezes. Also the other plumbing that has water in it needs to be drained and winterized properly or the same thing will happen to those too. (Manifolds, etc)
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
jefflaw35
Post by jefflaw35 »
i gotcha now, thanks. im liking the idea of that keel cooler system, im sure it pricy but it looks like all fresh water, never takes in raw water for anything
rcamaine
Post by rcamaine »
Jeff - you still have to winterize the salt water loop - i.e. make sure it is drained and often filled with aniti-freeze. My yard does that for me here in Maine so that if there is an issue - they are responsible.
The closed (fresh water/anti-freeze) loop is already set for winter. I do have them flush that though from time to time, just like a radiator flush in a car.
1980 36' Tri-Cabin - "Jeaga" - Maine
Commissionpoint
jefflaw35 wrote:i gotcha now, thanks. im liking the idea of that keel cooler system, im sure it pricy but it looks like all fresh water, never takes in raw water for anything
Keel coolers are nice, but they aren't really for your particular application.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
jefflaw35
Post by jefflaw35 »
so all this leads me to wander why i cant drop an old ford radiator with and electric fan down there, think its possible?
