need suggestions on truck bed liner in bilge?
yorklyn
Post by yorklyn »
Ok I need honest input . for those who do know i just replaced my stringers in my 10 meter. I then put two coats of west system over everything in the bilge as a barrier coat. I do industrial coatings for a living and have a 100 solids polyaspartic polyurea coating left over from a job in color stable white. polyurea is an extremely durable coating that is also flexible so it resists cracking (basically LineX truck bed liner) . the polyaspartic would go on in two 8 mil coats instead of bilgekote paint. I am now thinking of actually spraying our spray on version (just like LineX Liner) on at 60 mil (250 mil=1/4 inch) and then topcoating with the white which is rolled on. my biggest concern is added weight. about 10 Gallons of the spraying and 3 of the roll on. setting up to spray is a pita and will take me a day to set up. i have all material left over from jobs. I never ever ever ever want to replace stringers again! my wife and friends think im nuts! Im plan on doing the roll on at a minimum. am i crazy to do the spray as well?
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
ready123
Post by ready123 »
Enough work already.. start using the boat :!:
yorklyn
Post by yorklyn »
LOL!!!!!
Todd Pote
Double Pote-N_Sea
jddens
Post by jddens »
I have linex in my 1972 Chevy pickup bed. Other than weight it is kinda porous and rough.......might be hard to keep clean or to clean.....just t a thought............John
1998 Kawasaki ZXi 1100
I think it would be a poor choice , use bilge coat or some other paint .
alexander38
Post by alexander38 »
paint it... :wink:
Bilge area should be clean and easy to spot potential leaks. That's why many engine room and other access areas are painted white or a grey color.
As Paul mentioned, bilge coat or similar should be used. Good luck.
alexander38
mine are black.. :wink: got a Onan... :lol: :lol: :lol: :lol: but agree lt gray or white, ezer to see dropped parts to
jefflaw35
Post by jefflaw35 »
grey bildge coat is what im doing, white would just drive me nuts when i see it get dirty, and not to mention after 20 years of working on white cars, it can be blinding in the sun, even down there i would imagine if the light is hitting it correctly
If you used West System as mentioned, you could have employed an additive on a final coat that would give it a white finish, and that would have been better than anything you could add now as it would not be a coating that would eventually peel off but would actually be part of the hull.
foofer b
Post by foofer b »
huh
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
jefflaw35
Post by jefflaw35 »
Big D wrote:If you used West System as mentioned, you could have employed an additive on a final coat that would give it a white finish, and that would have been better than anything you could add now as it would not be a coating that would eventually peel off but would actually be part of the hull.
thats true, could have tinted your actual material. if its the pics i was thinking i saw, he did a nice slick flat finish, am i wrong?
yorklyn
Post by yorklyn »
Talk about unaniomus vote! my friends had an intervention on me tonight too! Aparently "overkill" was a term that came up alot! Think im going with the white polyaspartic coating without the spray on underneath.
Todd Pote
Double Pote-N_Sea
yorklyn
Post by yorklyn »
For the record, this is me doing one of the 1st test years ago with polyurea to "Up Armor" the bottom of a humvee for "bomb blast mitigation" testing with Polyurea. Overkill for my bilge? I think Not!!!!!!
[img][img]http://i247.photobucket.com/albums/gg14 ... 073-35.jpg[/img][/img]
Todd Pote
Double Pote-N_Sea
