Shaft coupler
Heefus
Shaft coupler
Post by Heefus »
So I should be getting my new prop shaft in this week. Should I replace the coupler as well? The fit, on the old shaft, is very tight but I would not go so far as to assume that it will be on the new shaft.
Also, I am going to repack the shaft seals, what size flax for a 1" shaft?
'76 F28
That would depend on the condtion of it ans if its running true .
Shaft packing is 1/4 on the 1"shaft
This may you help you get it done right
http://www.diybob.com/diyPackingGland.htm
BobCT
Post by BobCT »
I think 1" shaft might be 3/16", I know my 1.25" uses 1/4" packing.
1988 10m mid cabin
larryeddington
Post by larryeddington »
There is advice on web to always use an new one. IMO I cannot see how it could get loose as it has a keyed slot and as I just found out heat the flange and it should drop on and shrink to what Bob at Beacon calls a "light press". They also drill down the locking bolt holes to make a dimple in the shaft under each one. Once the bolts are tight ane safety wired on I cannot see how they could be loose or come off.
However you are using a new shaft and I would be asking myself, do I absolutely want to be sure?
Heefus
Post by Heefus »
I have no idea if the original coupler is true or not. i will stick a straight edge on it tomorrow and have a look see. Other than that, the shaft is keyed, sits flush at the end of the coupler, and is not egged out.
'76 F28
larryeddington
The hole is about 3 in long if key and set screws were intact, IMO, it should be tight.
Others may disagree I am reusing mine but going back on same shafts.
I just finished cleaning my shafts and deburing couplers, they look perfectly good on mine.
Something unusual though one of my coupler set screws is 1/4 inch shorter then the other three. Going to get one the same lenght as others as I am not 100% sure it will tighten into the dimple on the shaft, just to be safe. Too much work to have a problem.
BobCT wrote:I think 1" shaft might be 3/16", I know my 1.25" uses 1/4" packing.
Bob its 1/4 for sure as my 1 1/2 shaft .
shaft size---- packing size
1"--------------------1/4"
1 1/8"---------------3/16"
1 1/4"---------------1/4
1 3/8"---------------3/16"
1 1/2" --------------1/4"
1 3/4"---------------1/2"
2"--------------------3/8"
jefflaw35
Post by jefflaw35 »
my brain hurts again
Heefus wrote:I have no idea if the original coupler is true or not. i will stick a straight edge on it tomorrow and have a look see. Other than that, the shaft is keyed, sits flush at the end of the coupler, and is not egged out.
That won't tell you anything have the people making your shaft or someone else put it in a lathe
Last edited by prowlersfish on Mon Mar 19, 2012 10:47 pm, edited 2 times in total.
That won't tell you anything have the people make you shaft or someone else put in a lathe
+1 Get the coupler resurfaced.
Heefus
Post by Heefus »
I what direction am I looking for deviation? The mating surface must be flush, and the hole must be centered in the coupler, gripping the shaft tightly. Is there some other axis involved somehow?
'76 F28
the mating surface must flush and run true in relationship to the bore . the lathe is the way to do it , the right way .
Heefus
Post by Heefus »
Understood. I spoke with a vendor today. He stated that they pretty much throw it on a lathe, check the bore for egging, and check the mating surfaces for trueness and burrs.
'76 F28
BobCT
Post by BobCT »
hmmm... interesting chart on the packing. I always thought the packing size was always smaller or larger depnding on the shaft size. Not quite a linear scale now is it :)
good info...
1988 10m mid cabin
