F-25/F-26 Exhaust route
jefflaw35
Post by jefflaw35 »
I have been researching these differeneces for a week. Some like mine have 2 single ports of exhaust (dual), some are Y directed from the engine (single). I am wandering if I can Y mine off the motor, run striaght then Y again out my port holes. Or any other ideas of direction. I am designing my decking and looking to add fish lockers. Any free space helps. What is the purpose on these boats for Y exhaust like a car? Same engine as mine so why is mine dual exhaust?
larryeddington
Post by larryeddington »
Jeff my f28 withe two 318s have each engine into one four inch exhaust. Maybe that is why your engine said 235?
jefflaw35
Post by jefflaw35 »
i have dual exhaust, you maybe correct, the ones im seeing say 225. and they have One exhaust port....grr more confusing crap. Well im putting 225 back in her so I guess the question is, just how many different directions can I bent this system?
The Dog House
Post by The Dog House »
My F26 with a single Chrysler 225 (318) has twin exhaust, with one exhaust per exhaust manifold. There is no cross-over tube to equalize the pressure between the two. The engine runs very well with this setup.
Nothing wrong with going to single exhaust , It will sound better too IMO. Its very possible it came will single exhaust and was changed , seen this done many times . ( some people like the noise :) )
jefflaw35
Post by jefflaw35 »
that makes alot of sence as well. Now im just left with a really good sized hole to patch :shock:
Torcan
Post by Torcan »
I will try and get a pic for you Jeff of mine as you requested. I have just completely forgotten every time I am at the boat.
http://www.cbyc.ca/
jefflaw35
Post by jefflaw35 »
Ok thanks, heck I forgot I asked. I have found a couple online pics of the Y pipe but they are close up engine pics. I would be interested in seeing how the entire run looks, btw when I shake my mufflers they sound like a box of rocks. Should i replace them or just clean them out? Guess I will only need one of them now.
larryeddington
If they are the rubber ones, you cannot get them and will have to use something different as I am doing. Mine had two of the rubber ones per engine. It will not have one 4 inch one per engine.
The rubber ones had baffles inside which I will bet you are no longer there, exhaust just passes straight through.
You could use and exterior muffler if you're looking for more space inside, they are rubber. http://www.foreandaftmarine.com/mufflersSALISBURY.htm
This site says they have rubber in-line ones
http://yardeng.com/productwriteup.asp?id=14
jefflaw35
Post by jefflaw35 »
exccelent thanks D!! Im going to email them a picture of what I had and what I want!!
Torcan
Post by Torcan »
You asked for some pics on how my exhaust was set up.
here they are. :)
http://www.cbyc.ca/
jefflaw35
Post by jefflaw35 »
WOW thank you very much BUD!!! Im gonna nee that Y pipe, should be easy to get, then I can have a good sized fish locker on the oposite side of the decking. Thanks for the trouble with the pics, very helpful :D
alexander38
Post by alexander38 »
jefflaw35
Post by jefflaw35 »
sweet thanks Tony!
