WOT
Re: WOT
WayWeGo wrote: Fri Oct 11, 2019 12:20 am I think captainmainiac meant to say small block (318/340/360) and big block (383/400/440) engines...
As I said - not an expert... I don't build the darn things, just use them!
Re: WOT
Away wrote: Fri Oct 11, 2019 2:38 am And I am loaded with carbon due to excessive cruising at 1500. Looking at using Sea Foam in another post.
Sea Foam Any experience with this product for heavey carbon removal. Either added to the fuel supply or added to the crank case. Good, bad or better alternatives.
Why do you think you have a heavy carbon build up ? While I am not a member of the sea foam "club" it can't hurt . Nor can a long run at 3000 in fact it should do you some good .
kallen
Re: WOT
Post by kallen »
Something we use to do was dribble water down the throat of the carb to steam out carbon with the engine at 2000 rpm. Dont let the engine stall out.
You could also try some combustion chamber cleaner and follow the instructions.
Re: WOT
How do you know?
Re: WOT
Away, do your spark plugs look black and furry and the carbs run rich ( real smelly exhaust)?
AwayOnBusine$$
Re: WOT
Post by AwayOnBusine$$ »
Yes, Yes and Yes. We actually blew out a ton of carbon. Floating all over the place at start up. Marina mechanic was there, he confirmed. Next day could not get engine to fire up. Checked for fuel, checked compression, cleaned up the distributor cap. ok pulled a plug YUK dry black fuzzy. Others wet. Replaced them all fired right up. wanted to try SEA FOAM and a good half our run at 3000 rpm before sending carbonators in for an overhaul next spring.
F32 Fly 1975
Re: WOT
Away wrote: Sat Oct 12, 2019 2:48 pm Yes, Yes and Yes. We actually blew out a ton of carbon. Floating all over the place at start up. Marina mechanic was there, he confirmed. Next day could not get engine to fire up. Checked for fuel, checked compression, cleaned up the distributor cap. ok pulled a plug YUK dry black fuzzy. Others wet. Replaced them all fired right up. wanted to try SEA FOAM and a good half our run at 3000 rpm before sending carbonators in for an overhaul next spring.
Sounds very much like the carbs need attention, that will give you a black powdery looking residue in the exhaust water. Maybe the choke plates are stuck shut. If they are the original carter afb style carbs, I wouldn't waste too much effort on them. Good carb rebuilders up here are pricey and I don't mean just someone putting a kit in them.
You going to Florida this winter ?
AwayOnBusine$$
Re: WOT
Yes.
Not a mechanic how would I know if these are. If they are the original carter afb style carbs. If the answer is yes, are you indicating a different solution.
F32 Fly 1975
Re: WOT
The AFB carbs can develop air leaks at the butterfly shafts when old and that is expensive to fix. It's easier to buy Edelbrock 1409 carbs and install them.
