Goran, my F26 is 1977 with original engine (Chrysler Marine 318 w 225 hp at 4000 rpm) and original prop Nibral 14x9. I knew the original owner and have all the original paperwork, manuals, invoices, etc.
I believe Prowlerfish is correct that the 14x9 or 14x10 would be fine for your new diesel power.
Best Regards
Regards from new member
Re: Regards from new member
‘77 F26 HT Since 1999
Boppy
Thank you for info
Diesel engine is not new , I installed long time ago
But in mean time I add more than 500 kilograms for sure
Yes I find here on this forum 14x10 / 14x9 to be original for F25
BTW great choice on your solar charger , I have same brand
regards
Thank you for info
regards
Trojan 25F
Volvopenta 42
Lot of home-brew beer
Split-Croatia
Volvopenta 42
Split-Croatia
Hi Goran
Yes, I like the VictronConnect app too. Nice to see what is going on with solar power when I’m away from the boat.
You added 500 kilograms to your boat? Wow, that’s a lot of weight!
diesel engines are very sensitive to OVERPROPPING
OVERPROPPING will shorten the life of any diesel engine
suggest you make sure that your engines can reach the published maximum RPM while under load
Suggest you do this with FULL TANKS, fuel, water, waste
This is often overlooked, as boats tend to get heavier as owners add gear, equipment & spares
Hope this helps
Hope this helps
