Page 2 of 2
Re: distributor replacement M360
Posted: Tue Apr 26, 2022 7:35 am
by mikeandanne
Here is another thing to check. It has been a very long time but just remembered the oil pressure switch. At the rear of the engine you should find a tap with the oil pressure sender and a pressure switch which as I remember acted in the ignition circuit, It acted to allow the start. Maybe someone has the schematic for this, my drawings are long gone.
Unfortunately I just flat out don't recall much more, the instructions from the pertronix should have been fairly comprehensive to get around the points issue.
Also check your harness connector plugs, with working around there they could have become damaged or loose.
Posted: Tue Apr 26, 2022 9:33 am
by TADTOOMUCH
I removed the ballast resistor and jumpered across both connectors to the ballast resistor at each end virtually connecting all four wires. I wanted to do this until I prove the thing works before I cut off the connectors and join all four wires and connect them.
Posted: Tue Apr 26, 2022 1:53 pm
Run direct 12volts to the coil+
Posted: Sat Apr 30, 2022 1:01 pm
by TADTOOMUCH
Ok I ran 12v from the ignition switch relay to the + on coil. I found TDC on the compression stroke for #1 cylinder. Installed the distributor. Hooked up the #1 wire to post of dist. cap where rotor is pointing and installed the wires in the correct clockwise firing order. She fires but only get a backfire out carburetor. I’ve checked in on the compression stroke several times, tried the flipping 180 of the distributor. I have unplugged the old ignition module and removed the ballast resistor all together.
Can’t get her to run. It was running fine before this install
Any help?
Posted: Sat Apr 30, 2022 2:42 pm
by mikeandanne
TADTOOMUCH wrote: Sat Apr 30, 2022 1:01 pm Ok I ran 12v from the ignition switch relay to the + on coil. I found TDC on the compression stroke for #1 cylinder. Installed the distributor. Hooked up the #1 wire to post of dist. cap where rotor is pointing and installed the wires in the correct clockwise firing order. She fires but only get a backfire out carburetor. I’ve checked in on the compression stroke several times, tried the flipping 180 of the distributor. I have unplugged the old ignition module and removed the ballast resistor all together.
Any help?
Ok, which engine is this ( what side ), firing orders are for standard 1-8-4-3-6-5-7-2, reverse is 1-2-7-5-6-3-4-8 . A pop in the carb is a few things, no fuel or not enough to fire, the more likely is timing wrong. Set it like you have, the damper should show right on tdc, turn the engine back so about 10 degrees advanced about a 1/2 " then set the rotor to #1 and try with the correct firing order for your engine rotation, you may have to adjust the dizzy as you crank.
Posted: Sun May 01, 2022 9:02 am
by TADTOOMUCH
I’m on starboard engine that rotates clockwise. Both distributors rotate clockwise on the 360’s as most of us already know.
Posted: Mon May 02, 2022 2:21 pm
by Brooks
My notes from my 318 conversion
PORT MOTOR STD / LH / CCW 1-8-4-3-6-5-7-2
STBD MOTOR REV / RH / CW 1-2-7-5-6-3-4-8
Black wire = - COIL
Purple White wire = + COIL
The biggest thing was that #1 at the distributor wasn't where I predicted. I literally used a plug wire in #1 cap, to a grounded plug to fish around / see where it really fired - because it wasn't where I thought it would be. Then plugged in the cap by the above table, and then timed by feel, and then timing light. It's worth the effort - Saw almost 30° of total advance - which was great. Never had a ping since. Carb also needed adjustment. Very happy to eliminate the entire Chrysler pentamic(?) ignition, etc.
Good luck!
Brooks
Posted: Sat May 07, 2022 5:02 pm
by TADTOOMUCH
Finally figured out the correct firing order for starboard from reversing the port firing order. Then all was well and engine runs great until I saw water coming in from a crack in the muffler! When it rains it pours with a boat!
Posted: Sun May 08, 2022 9:02 am
Glad you got her running.
Posted: Sat May 28, 2022 2:40 pm
by TADTOOMUCH
Engines running great! New muffler installed $360 in case anyone needs to know. Time for sea trial this weekend to see if this was all worth it. Anyone need two 12v coils for ballast resistor system? Anyone need 3 ballast resistors or ecu units and two prestolite distributors? I will make you a great deal.
Posted: Sun Jun 05, 2022 8:17 pm
by TADTOOMUCH
Sea trial with new coils, new distributors and new muffler went very well. First time I have been able to see 4000+ rpm’s. Never stalled once after coming into the harbor. It’s been a long battle finding the root cause of this problem.
