does anyone know...
the port motor has the "mercruiser 233" decal on the valve covers. i'll try and post pics of the motor. they have two barrel carbs on them. from what i was told the block on the 302 and 351 are the same but the heads are different. this is why i was never a ford man! [img]http:/s666.photobucket.com/albums/w26/chauzer2[/img]
life is tough! it's even tougher if your stupid.
~john wayne~
~john wayne~
"A simple differentiator between the Windsor and Cleveland series is the location of the radiator hose — the Windsor routed coolant through the intake manifold, with the hose protruding horizontally, while the Cleveland had a dry manifold with the radiator hose connecting vertically to a separate timing chain cover."
From Wikipedia, the free encyclopedia!
You won't find 351 Clevelands used very much in marine use . 99.99% were winsors I don't know of any production marine engine company that use the Cleveland. why ? I would guess it is becuse they took up more room and weghted more and were the same HP .( and may have cost more ) Yes they did have better heads but at the HP used for "stock " type marine engines it did not matter. I always thought the winsor had better low end and was better on fuel .
