I want battery voltage gauges to install on my F44, suggest?
jwrape
Post by jwrape »
RWS wrote:When I updated my charger I added the Blue Sea System voltmeter.
It is a nice analog gauge and has a 3 way toggle switch.
Simply run wires direct to each battery with a tiny .5 or so amp fuse in each.
Now I can check the actual voltage of each of three batteries at any time while running, charging or on the hook.
This has saved my butt several times and also has alerted me to when an older battery is beginning to fail.
When I bought mine it was about $55 now they're a bit more. Try BEACON MARINE FIRST
Here's a reference with a photo
http://www.westmarine.com/webapp/wcs/st ... assNum=694
That's what Iam talking about exactly.
79' Carver 28' Mariner
If you were to add an additional, external switch you could cover six seperate batteries from this panel.
It's very useful and I would not be without it.
It can help you avert disaster, it's done it for me!
Post by Paul »
I have a 2 bank version of the analog gauge that RWS spoke of. When I'm on the hook for a couple days, a simple flick of the switch shows me the battery status and I know if it's time to start the generator for a re-charge.
I bought it at Westmarine abour 4 years ago for $45.
gjrylands
Post by gjrylands »
In stead of buying a volt meter from Blue Sea or any other manufacture I put together a volt meter from parts I bought from Radio Shack at a fraction of the cost. All you need is to buy a volt meter, a non-shorting rotary switch, in line fuse holders, and some wire. Total cost around $40.00. I don’t have a current Radio Shack catalog so my prices will be estimates but these are the parts:
1. Panel Volt meter 0-15VDC 22-410 $20.00 (Digital volt meter could be used but is more expensive)
2. 6 position Rotary non-shorting switch 275-1386 $5.00 (This is a 2 pole switch, but you will only use 1 pole of the switch)
3. In line fuse holder 270-1281 $2.00 (You will need one for each battery) (4 batteries $8.00)
4. Glass fuses 0.25A 270-1002 $2.00
5. Hook-up wire #18 - #12 $($5.00) (You will need enough wire to run a wire from each battery to the switch. Wire size should be determined by the length of the run.)
Run a wire with a fuse holder from the positive terminal of each battery to terminals on the switch. A 6 position switch will handle up to 5 batteries. The first position of the switch will be the off position. Run the output terminal of the switch to the volt meter. Since all batteries have a common ground you can pick up the ground or – side of the battery from most anywhere. This is connected to the – side of the volt meter. Once installed, you can check the voltage in each battery by rotating the switch. When finished checking, you can turn the volt meter off.
The rotary switch I recommended is only rated at 0.3A. You need to use a non-shorting rotary switch to protect the switch when switching between batteries. If the batteries being checked aren’t at the same voltage you can get a serge of current and fry the switch. The non-shorting switch keeps this from happening.
Gerry
1979 F36 Twin Chryler 440's
jwrape
Post by jwrape »
gjrylands wrote:In stead of buying a volt meter from Blue Sea or any other manufacture I put together a volt meter from parts I bought from Radio Shack at a fraction of the cost. All you need is to buy a volt meter, a non-shorting rotary switch, in line fuse holders, and some wire. Total cost around $40.00. I don’t have a current Radio Shack catalog so my prices will be estimates but these are the parts:
Very nice... How did you mount it all? Got a pic of it?
gjrylands
Post by gjrylands »
I put in an auxiliary DC power panel and incorporator the volt meter in the panel. I’m going to the boat today and will take a picture of the panel and post it.
You can mount the volt meter anywhere it will fit. The meter is 2 ¼” high and about 3” wide. It mounts in a 1 7/8” hole. The switch mounts in a 7/16” hole. You will need about 1 1/2 “ of clear space behind the hole to accommodate the switch.
Gerry
jwrape
Post by jwrape »
Cool, Thanks
gjrylands
Post by gjrylands »
This is a picture of the auxiliary DC power panel with the voltmeter.
Gerry
gjrylands
Post by gjrylands »
If the volt meter looks too modern you can use any DC volt meter with the proper range. The key to the instalation is the rotary switch. If you have room in the dash you can install a 2" round volt meter. You should be able to find one that would match the gauges you have. You should be able to find a place to install the switch so it would be close to the gauge.
Gerry
jwrape
Post by jwrape »
Great, nice installation....
Thanks for the pics
randyp
Post by randyp »
Just saw this in the Boat/US Magazine.
http://www.argusanalyzers.com
The "Battery Bug" is designed for auto and marine applications, starting and deep-cycle (up to 300 AH).
Looks and sounds simple to install and use.
Randy P
1977 F-26 HT
"Blue Heron"
wet wonder
Post by wet wonder »
I have an F-25 and all my inside sytems, fridge, faucet and shower pump, fans, tv, dvd, cd, stereo, lighting are all twelve volt, with a dedicated battery bank thoroughly fed by solar panels on the hard top - so monitoring voltage is important on board. I use a power panel with a voltage gauge like gjrylands. I don't recall off-hand the brand, but it is a five fuse and cost about $125. It really is perfect.
