no spark
get a test light or a volt meter.
check for votage at the positive side of the coil.
If the coil has an internal resistor there should be 12 volts there.
Once you have that answer, you can begin tracing down the problem.
Interesting that the same problem exists on BOTH engines.
capt ralph
we now have spark
Post by capt ralph »
hi guys.the problem was the fire system.it was cutting off the power.over the winter something happened.there was no pressure.got it all fixed now,and the engines start right up.
thanks for all the advice
capt christopher bouchard
kevin babineau
Post by kevin babineau »
thats great!!
jwrape
Re: we now have spark
Post by jwrape »
capt ralph wrote:hi guys.the problem was the fire system.it was cutting off the power.over the winter something happened.there was no pressure.got it all fixed now,and the engines start right up.
Excellent. Glad you found it.
79' Carver 28' Mariner
