F-28 Performance
shawzy44
Post by shawzy44 »
I've been playing with the tabs for a while now. I have them reacting MUCH quicker and can get her to plane fairly quickly.
I get about 12kt @2700 RPM and WOT 23kn @4400 RPM full fuel and water.
Kevin
1979 F-28 "Rumset" w/ twin Chrysler 318's
2005 Mercury Marine 310 Sport w/ 15hp
Centre Point Landing, Bobcaygeon, Ontario
herpleasure
Post by herpleasure »
Dreamer,
I am interested in your props. I have a 79 f28 that is doing 2800PRM (which is all it will do) and 12 MPH. The motors run good. You seem to have found the key
Current fleet:
2003 84' Stardust Cruiser
1979 28' Trojan
1969 17'Tom Sawyer
2003 20' Prince Craft
1972 14' Fishing boat
2001 9' Pelican
2000 Bombardier Jet Ski
herpleasure wrote:Dreamer,
Sounds like you have a fouled bottom and or running gear
Dreamer
Post by Dreamer »
The two things that made the biggest in Dreamer, was rebuilding the engines with a very mild cam. New carburetors, and stripping the bottom and using VC-17. I know that's more than two. The props I believe are at the factory pitch.
Better than I deserve
willietrojan
Post by willietrojan »
I guessing your engines are the original, how many hours? I would suggest getting a compression test, this sound like the engines are worn out
Spanish Fort, Al
Looking for 33 International
2800 rpm should be faster then 12 MPH . 2800 rpm is 2800 worn out or not ,
Willie have you found a new boat yet ?
Capt. Z
Post by Capt. Z »
prowlersfish wrote:2800 rpm should be faster then 12 MPH . 2800 rpm is 2800 worn out or not ,
I have to agree with Paul. 2800rpm is where I cruise at with my F28. 2800rpm is right at 22mph, WOT is 4100 rpm at 34mph. The 318s are no where near fresh either, 1600hrs.
With a little more info maybe we can help you get to the "bottom" of your problem!
Twin 318 powered 1976 F28 "Think BIG IIi"
foofer b
Post by foofer b »
prowlersfish wrote:It is not a engine problem !!!!! your only gets 13-14 knots at 3200 ? well no matter what you do to those engine you still only going to get 13-14 knots at 3200. you could tune them up put a blower on it and get 700 hp out of them But your still only going to get 13-14 knots at 3200 rpm .
unless the engine is missing don't waste you time with a compression check . even if you had 2 dead clyders it will not change your speed at a given rpm. (yes of course it would efect top rpm. )
look else where
Once again Prowlerfish is spot on. Rpm is Rpm no m,atter what the HP.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
captainmaniac wrote:If you have to give your mechanic a list of what to check to diagnose your problems, maybe you found your problem - you need a new mechanic! If he can't tell *you* what needs to be checked, don't let him touch them.
omg ! we agree :shock:
I've a question, will it rev up out of gear ? lack of gas at higher rpm it'll back fire and or fall off all together. And whats the bottom look like a fouled bottom or a painted one that looks like the moon will kill rpm/speed. also have you checked alignment ?
And engine hrs. don't kill engines lack of maintenance kills them, my 454's have over 1700 on them and push me up 25 knots with a smooth bottom.
shawzy44
Post by shawzy44 »
Alexander38,
What do you mean by alignment? Alignment of what exactly?
Kevin
Engine alignment
prowlersfish wrote:Engine alignment
to shafts and cutlass bearings
Not exactly , you aligne the engine to the shaft and the shaft to the cutlass , its really 2 different things to do , but one effects the other . as a general rule , cutlass/strut alignment will effect cutlass wear , engine to shaft can cause vibration and possible shaft failure .
To cause a power loss the alignment would have to be so far off the shaft would be in a bad bind . if you can rotate the shaft then I don't think this is the issue .
